View Poll Results: What engine suffix for a 9561?
'69 COPO 427 Engine 0 0%
COPO 9561 Engine 0 0%
427/425 4 Spd. '69 1 25.00%
TO512MN BLOCK 3 75.00%
Voters: 4. You may not vote on this poll
Old 07-29-2021, 05:17 AM
Maxibrake Maxibrake is offline
Default Looking for the '69 COPO Camaro 4Spd. this L72 belongs in?!?!
Hello guys, I'm new here and thought I'd throw this out there and hopefully, find the car this engine belongs in.. Pretty sure it's a '69 COPO L72 427/425?? It runs, big, solid flat tappet cam. Heads are the CORRECT "291" Square castings but the date is too late (J-30-9) I haven't disassembled yet.. Came out of a '67 Caprice I recently purchased. Pulled it to put a tamer 454 in and checked numbers and researched how rare this engine(Or at least the block) is... Hoping the car is still around?? Trying for some good photos tomorrow.. NUMBERS BELOW��
*Block #3963512
*Block casting date is C-11-9
*Right Front deck stamping is TO512MN. Correct to a (4SPD.) COPO
*VIN#19N 9487(Above oil filter, vertically on block bell flange) 19N I'm pretty sure is a Camaro installation?..Only the last 4 of VIN (not 6)are stamped here. I've read that Norwood got sloppy on protocol sometimes?
Thanks very much!
Blake Bailey
Attachments - The Supercar Registry IMG_20210726_200321772.jpg IMG_20210726_200234679.jpg IMG_20210726_200140110.jpg IMG_20210726_200004411.jpg
Old 07-29-2021, 05:29 AM
Sorry, RPO CODE L72
Old 07-29-2021, 02:52 PM
jeremy clark jeremy clark is offline
Well, whoever took the grinder to the VIN number all but ruined it for the whoever may own the car.... since the surface has been ground on, the VIN stamping will always be suspect. Not cool.
The Following 5 Users Say Thank You to jeremy clark For This Useful Post:
big gear head (07-29-2021), Billohio (07-29-2021), GotGrunt (07-29-2021), m22mike (07-29-2021), X66 714 (07-29-2021)
Old 07-29-2021, 03:07 PM
Let this be a lesson...do not ever, EVER, EEEEEEVVVER under ANY CIRCUMSTANCES use a grinder or even sandpaper to clean a numbered surface on a potentially valuable engine or any other vintage car part for that matter. You have SERIOUSLY devalued that block.
The Following 3 Users Say Thank You to jeremy clark For This Useful Post:
big gear head (07-29-2021), m22mike (07-29-2021), X66 714 (07-29-2021)
Old 07-29-2021, 04:03 PM
jl8z28 jl8z28 is offline
The first numbers should start with 65?
Old 07-29-2021, 04:21 PM
lowmile lowmile is offline
Am i missing something? Isn't a restamp anyway?
Old 07-29-2021, 05:34 PM
bergy's Avatar
bergy bergy is offline
Assembly stamp looks awful "new", but characters look correct and a good date. I believe that this is a good stamp from that assembly date.
lowmile (07-29-2021)
Old 07-29-2021, 08:30 PM
Doesn't look bad compared to that stamp.
Old 07-30-2021, 11:29 AM
