Old 08-05-2021, 10:52 PM
Default Interesting Vintage Rollerized Roller Cam Crower Imperial
I recently bought a 66 Corvette 427/425HP engine from a member. He found the engine in a 1968 Camaro show/drag car that was found in a storage locker that was sold due to back rent. The car had very high end components for the period. The engine had a heavily modified 427 crank, Howard aluminum rods, a tunnel ram with dual dominators, etc. It also had this cool Crower roller cam. I had never seen a cam like this before and thought I would share. The cam bearing journals are actually rollerized. The bearing journals have been turned down to a small diameter and 2 cast shells hold the needle bearings in place. A quick Google search for Crower Imperial cam showed that these were the high end option for a roller cam back in the day. Anyway, I just thought I would share.
Jason
The Following 7 Users Say Thank You to SuperNovaSS For This Useful Post:
69M22Z (08-06-2021), big gear head (08-06-2021), Damien (08-05-2021), markinnaples (08-06-2021), PeteLeathersac (08-06-2021), seventieshow (08-05-2021), Steve Shauger (08-06-2021)
Attachments - The Supercar Registry P8055072.JPG P8055070.JPG P8055069.JPG P8055068.JPG
Old 08-05-2021, 11:49 PM
Wow....what did the Camaro look like, Jason?
seventieshow (08-06-2021)
Old 08-06-2021, 12:36 AM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
Interesting.
I will let the member who owned it reply if he chooses.
Jason
Xplantdad (08-06-2021)
Old 08-06-2021, 12:50 AM
cook_dw's Avatar
cook_dw cook_dw is offline
Very cool. Thanks for sharing. Definitely extremely high end.
Old 08-06-2021, 02:41 AM
Wow that was a lot of work and engineering in that package, was it running a gear drive as well?
I can't recommend Crower enough - Dave Crower is the professor at spec'ing a cam.
Old 08-06-2021, 02:43 AM
scuncio scuncio is online now
Wow! That must be FUN to assemble. Cool piece.
Old 08-06-2021, 02:50 AM
No, I was surprised. It had a simple double roller chain. It was dated early 70 so I believe it was installed with the cam.
Jason
