Old 06-23-2021, 02:06 PM
That hydraulic flaring tool is the same one that I have. It works great.
The Following 3 Users Say Thank You to big gear head For This Useful Post:
dykstra (06-25-2021), RPOLS3 (06-23-2021), Too Many Projects (06-23-2021)
  #52
Old 06-23-2021, 02:54 PM
napa68 napa68 is offline
x 10,000
The Following 3 Users Say Thank You to napa68 For This Useful Post:
  #53
Old 06-23-2021, 10:21 PM
Originally Posted by RPOLS3 View Post
Good to know Bill - it appears based on what I saw last night that there is one clip near the rear seat body mount that is fastened from the top and would be difficult (maybe not impossible) to remove and replace? Is that the only one?
That is the screw I have raised the body 1/2-3/4" to remove. It also gives a little "wiggle" room to maneuver the line around. Amazing what less than an inch of clearance can do to make a job go better.
RPOLS3 (06-24-2021)
  #54
Old 06-23-2021, 10:32 PM
67since67's Avatar
Apparently there IS a difference from '67 to the later Chevelles. Only snap-in clips for the brake line on a '67, all easily accessible. Sorry!
RPOLS3 (06-24-2021)
  #55
Old 08-19-2021, 01:13 AM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Update on things.......got a call from Karp's this afternoon after 8 weeks and the brake distribution valve is not rebuildable, they can't get the front half apart, which explains why I could not get fluid to the front calipers. Sooooooo if anyone out there has a cast iron distribution valve for a March 72 Kansas built Chevelle with front discs I am interested....looks like the one pictured below. I will also post in the wanted section.
Jake Dykstra
Dykstra Motorsports
Old 08-27-2021, 11:03 PM
I had a similar looking "BENDIX" brake valve rebuilt for my brother's 73 Z28.
The company had never done the style before SO I sent 2 valves ONE for them to experiment with and the original from the car. Told them I didn't care what they did to the additional valve, I didn't get the "experimental valve returned but did get the original rebuilt for about $100. I know of at least one other Nasty Z28 board member who also had their vavle rebuilt by Old Auto Restorations.
James Ament
308 Cambridge Lane
Lititz, PA 17543
RPOLS3 (08-30-2021)
  #57
Old 08-29-2021, 04:39 PM
1972convss454 1972convss454 is offline
Jake I could not find the one I have somewhere.....I did remembered I have a frame from an Arlington built 72 W Code January Date that you are more than welcome to if you would like to give it a try.
Joseph Farrow
1970 Chevelle L78
1970 Chevelle LS6
1972 Chevelle LS5
The Following 2 Users Say Thank You to 1972convss454 For This Useful Post:
PeteLeathersac (09-07-2021), RPOLS3 (08-30-2021)
  #58
Old 08-30-2021, 11:51 AM
RPOLS3's Avatar
Sure! Thank you very much. I'll PM you with my information. Appreciate it.
Jake Dykstra
Dykstra Motorsports
Old 09-07-2021, 05:00 PM
RPOLS3's Avatar
Big shout out to Joe Farrow (72convSS454) - he found a valve and sent it to me no charge. Thank you very much Joe! Much appreciated.
Off to the rebuilder's in hopes we can make this one work.
Jake Dykstra
Dykstra Motorsports
The Following 7 Users Say Thank You to RPOLS3 For This Useful Post:
1972convss454 (09-07-2021), big gear head (09-07-2021), dykstra (09-08-2021), GearheadSS (10-05-2021), olredalert (09-07-2021), SuperNovaSS (09-08-2021), Xplantdad (09-08-2021)
  #60
Old 09-07-2021, 05:05 PM
Awesome!!
