  #24
Old 10-05-2021, 10:10 PM
atremblay atremblay is offline
i also replaced the front pump seal on trans it was seeping and leaving a quarter size drip overnight also replaced the torque converter while i had trans out Had door panels off to clean all window regulator and white lubed the regulator tracks the power windows worked like new after i cleaned and lubed them . everything worked even the trunk light . I di all the mechanic work myself i can do alot on a classic cars been working on cars since the 60's
The Following User Says Thank You to atremblay For This Useful Post:
PeteLeathersac (09-02-2022)
