Old 09-13-2021, 10:03 PM
Mated up the subframe and the body...
Bruce dropped off a load of parts earlier today - gardener exhaust, complete interior, radiator etc I am getting excited!
The Following 16 Users Say Thank You to firstgenaddict For This Useful Post:
1967 4K (10-24-2021), 427TJ (05-28-2022), bergy (09-14-2021), jbtech (09-23-2021), John (09-19-2021), McCune (09-14-2021), napa68 (09-14-2021), olredalert (09-14-2021), PeteLeathersac (09-13-2021), R68GTO (09-13-2021), RPOLS3 (09-14-2021), ScottG (10-29-2021), Steve Shauger (09-14-2021), Woodrock (09-14-2021), X66 714 (09-13-2021), YenkoYS-199Stinger (10-22-2021)
  #42
Old 09-14-2021, 06:16 AM
Looking great!
Am I crazy or is that fan mounted backward on the clutch?
Jason
Old 09-14-2021, 01:52 PM
You're not crazy...
Old 09-14-2021, 08:55 PM
bergy's Avatar
bergy bergy is offline
you guys are WAAYYY too observant! My fault - not James.
Old 09-17-2021, 08:10 PM
Dotkip Dotkip is offline
Any luck mate ?
Old 10-22-2021, 01:10 PM
More photos - gardner chambered exhaust, all the cocktail shakers and the spatter paint.
The Following 11 Users Say Thank You to firstgenaddict For This Useful Post:
1967 4K (10-24-2021), 427TJ (05-28-2022), bergy (10-22-2021), enio45 (11-02-2021), John (11-02-2021), NorCam (11-03-2021), olredalert (10-24-2021), PeteLeathersac (10-24-2021), RPOLS3 (10-25-2021), ScottG (10-29-2021), Steve Shauger (10-22-2021)
  #47
Old 10-23-2021, 09:00 PM
169indy's Avatar
169indy 169indy is offline
Sweet Progress!
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 10-26-2021, 03:06 AM
duskblue duskblue is offline
looking good James
Old 02-01-2022, 03:41 PM
More photos - the RS hose kits do not have a orange striped hose which is what the originals had so I restriped the actuator hose orange and fixed the yellow on the hoses as well.
NOS Trico splitter -
The bottle of electrical joint compound which I use on all grounds and wire plugs.
The tail lamp housings sometimes are deformed and will not hold the lenses very well. I submerge them in boiling water for a few minutes then use a clamp to pull them in - then set the change using cold water in a pump up spray bottle.
The Following 7 Users Say Thank You to firstgenaddict For This Useful Post:
427TJ (05-28-2022), bergy (02-02-2022), Billohio (02-05-2022), Jims69z28 (02-02-2022), L_e_e (02-02-2022), olredalert (02-01-2022), RPOLS3 (02-01-2022)
  #50
Old 02-01-2022, 03:55 PM
cook_dw's Avatar
cook_dw cook_dw is offline
As always amazing work James.
