Exactly why I was asking.
Rick Nelson Musclecar Restoration and Design, Inc (retired) www.musclecarrestorationanddesign.com https://www.youtube.com/watch?v=62r-6vgk2_8 specialized in (only real) LS6 Chevelle restorations |
That seems to vary sometimes. Not to steer off subject but when it comes to aluminum intakes, I think the BBC used washers under the bolts from originals I've seen, but some SBC aluminum intakes didn't.
I know the 69Z's did not use washers under the bolts on the intakes. Doesn't really make a lot of sense but that's what I've observed. Different assembly plants I know, but bolts gulling up aluminum you would think would want washers as kind of a standard procedure across the board. |
That is correct, the BB engines (at least in 69/70 used a washer headed bolt other than where the engine lift bracket was bolted to just like in Charley's photo.
