Old 11-09-2021, 04:55 PM
Rumbleguts396 Rumbleguts396 is offline
Default BBC chrome valve covers ID
Hi Guys, I just picked up this pair of chrome BBC valve covers. I’m trying to ID the year and model car they were used on. I know there a several variations between years/models. Any help would be appreciated. Thanks Rob
1969 Camaro SS 396 X66 Lemans Blue
1969 Corvette 427/390 Lemans Blue
Attachments - The Supercar Registry 9CF5D1E4-7536-4250-B48D-0274794C71F5.jpg 8E77620F-F6AD-44FB-81AE-D626F85ADF9B.jpg 7E1FD43D-94FA-485D-8026-56CF7D118C31.jpg
Old 11-09-2021, 05:21 PM
169indy's Avatar
169indy 169indy is offline
Rule out "F" Body.
Re. the Driver side spark plug wire stand would be located farther forward.
(Others can fact check me)
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following User Says Thank You to 169indy For This Useful Post:
Rumbleguts396 (11-09-2021)
Old 11-09-2021, 08:47 PM
Unreal Unreal is offline
Not positive, but with that little dimple on the driver side, and the location of the spark wire tower, I think it's 69 Chevelle, only. I know that dimple with the forward tower is 69 Camaro, only. Also has the temp sending unit wire clip on the driver side cover, which I think is 69 only, but not 100% sure.
I know I searched far and wide to find the correct driver side valve cover for my 69 Camaro. Some had the dimple without the sending unit wire tab, but I don't remember the application. 69 Camaro only had the dimple, the forward tower, and the tab.
The Following User Says Thank You to Unreal For This Useful Post:
Old 11-09-2021, 10:53 PM
DWR DWR is offline
1970 chevelle had the temp sending unit wire clip on the drivers side cover also.
The Following User Says Thank You to DWR For This Useful Post:
Old 11-10-2021, 02:52 AM
Right, I meant that only 69 Camaro, (and probably Nova) had all three, forward spark wire tower, that style of dimple, and the sending unit wire tab. 68's were different, as were 70's.
Rumbleguts396 (11-10-2021)
Old 11-10-2021, 01:29 PM
bbjohnny bbjohnny is offline
Should be 69 Corvette, Chevelle and High Perf passenger.
The Following User Says Thank You to bbjohnny For This Useful Post:
