Old 12-11-2021, 07:12 PM
302moz 302moz is offline
Default 3/4 pipe plug W head
Wanted a 3/4 pipe plug with W on the end . It is the plug above the oil filter on a big block Chevrolet . The four bolt blocks use the bigger 3/4 plug . Please call /text 9063371025 thanks
Old 12-11-2021, 08:52 PM
You can buy a Dorman made plug from a good auto parts store and stamp a W in the center using a stamp set machinists use. Once the block / plug are painted you can not tell either way. Most original plugs do not come out easily and need to be drilled out. So re-using them is impossible.
Bill
Old 12-11-2021, 10:44 PM
ALLZS ALLZS is offline
Default Plug
Here is one
