Old 12-20-2021, 08:16 PM
MarcDant's Avatar
MarcDant MarcDant is offline
Default Air compressure warning
https://www.youtube.com/watch?v=sm_FJ6Pat4I
Saw this on you tube .
The Following 5 Users Say Thank You to MarcDant For This Useful Post:
69M22Z (12-20-2021), dykstra (02-07-2022), earntaz (12-20-2021), L_e_e (12-21-2021), roadster (12-21-2021)
Old 12-20-2021, 08:57 PM
69M22Z 69M22Z is offline
Wow.
Old 12-21-2021, 02:58 AM
MarcDant's Avatar
Originally Posted by 69M22Z View Post
Wow.
Yup, first thing i did was shut my 25 year oid compressor off. I will turn it on only when i use it. Lucky the dudes kid was not in the garage when it went off like a grenade as he said .
Old 12-21-2021, 05:14 AM
markjohnson's Avatar
markjohnson markjohnson is online now
Man, it is absolutely imperative to have an easy-to-access ball valve on the bottom of the tank to blow that moisture out (OFTEN!) to avoid situations like this. Also, keep a sharp eye on that pressure limit switch that’s easy to adjust or replace if need be!
The Following User Says Thank You to markjohnson For This Useful Post:
earntaz (12-21-2021)
Old 12-21-2021, 09:00 AM
Yes. Very lucky that nobody was near that compressor.
Old 12-21-2021, 11:06 AM
Ralph Spears's Avatar
I have a 42 year old SEARS compressor that i still use i often thought about it giving out
Old 12-26-2021, 01:37 PM
CamaroNOS CamaroNOS is offline
Compressed air, a lot of us take it for granted but it can be like dynamite.
I too have a portable compressor in my shop which is only on when needed. Is there a way to check internally the integrity of the steel chamber?
Paul
Old 12-27-2021, 07:58 AM
MarcDant's Avatar
Paul you could probably check with a telescopic camera thru the hole on top were switch mounts into, with a bright light along the bottom welded seam and you can make this cheap air dryer and remove a lot of moisture that would otherwise settle on the bottom of compressor.
Old 12-27-2021, 12:45 PM
TimG TimG is offline
I bought my Sears air compressor in 1975 when I was in college. It maxes out at 85 pounds, but I'm sure that could cause a problem.
Old 12-27-2021, 01:47 PM
Rfish Rfish is offline
That’s 85lbs pressure per square inch multiplied over the volume of the tank so yeah, it’s still scary to think of the damage that could cause. This is one of the reasons the Europeans have very strict inspection criteria on pressure vessel certifications. Here in the US, not so much unless related to industry/business and even then it is not well regulated..
I work on equipment that had a large pressure vessel certified to 600psi which we operated to 310 PSI. When we decided to have some upgrades done the UK vendor refused to work on it because it had not been recertified within their guidelines.
The Following User Says Thank You to Rfish For This Useful Post:
MarcDant (12-27-2021)
