Old 01-03-2022, 11:58 PM
67since67's Avatar
Everything here gets VR1 10W30 with NAPA Gold Wix except the Day 2 which gets 20W50.
The Following 2 Users Say Thank You to 67since67 For This Useful Post:
67 Nova Boy (03-06-2022), ruralrte66 (01-05-2022)
  #12
Old 01-04-2022, 01:39 AM
ruralrte66 ruralrte66 is offline
Default Vr1
Originally Posted by RALLY View Post
Valvoline 10W30 VR1 oil is one of the best on the market. Wix oil filters are the best too. To much ZZDP additive is not good.
What a great thread, I have always used Valvoline 10w40 and Napa Gold filters.
Should I change to 10W30 VR1? What about oil change intervals, since they sit more than get driven?
Thanks Gregg
Old 01-04-2022, 01:42 AM
1BADZ28 1BADZ28 is offline
Default Great Info from everyone
Great Info from everyone....Good to hear all the opinions and knowledge being shared....
Old 01-04-2022, 01:45 AM
RALLY RALLY is offline
Thanks Gregg
Hey Gregg, Yes you should use the Valvoline 10W30 VR1 racing oil and good Zinc protection for flat tappet engines. 10W40 is to heavy. I know a engineer who tests motor oils and he told me the Valvoline 10W 30 VR1 racing oil is one of the best oils out there. NAPA filters are made by Wix, very good quality. Motorcraft was told by the engineer are the best out there.
The Following User Says Thank You to RALLY For This Useful Post:
ruralrte66 (01-04-2022)
  #15
Old 01-04-2022, 02:32 PM
Default Part number for Wix oil filter
Hey, anybody know what the part number is for a Wix oil filter for a 69 Camaro 396/325 HP ? Thanks....
Old 01-04-2022, 02:44 PM
Default Wix-51069r
I think I just found it....WIX-51069R, WIX Racing Oil Filter Height: 4.33"
Thread Size: 13/16-16
Bypass Valve: None
Anti-Drain Back Valve: None
Max Flow Rate: 28 gpm
Is this it?
Old 01-04-2022, 02:59 PM
X66 714's Avatar
X66 714 X66 714 is offline
Bypass Valve: None
Is this it?
I was thinking the 51069, the non race filter. I thought the race filter had less filteration for greater flow. No micron rating on the race filter. Been 30+ years since I worked at NAPA.....Joe
Old 01-04-2022, 03:16 PM
napa68 napa68 is offline
Joe is right.......just use the 51069 or the NAPA number is 1069
Tim
The Following 2 Users Say Thank You to napa68 For This Useful Post:
Billohio (03-04-2022), X66 714 (01-04-2022)
  #19
Old 01-04-2022, 03:57 PM
Default Got it...
Got it...Thanks Joe and Tim
The Following User Says Thank You to 1BADZ28 For This Useful Post:
  #20
Old 03-04-2022, 01:00 PM
GearheadSS's Avatar
GearheadSS GearheadSS is offline
I've used VR1 10w30 and Lucas Hot Rod 10w30. I know a lot of folks run Shell Rotella T 15w40 diesel oil too. VR1 is usually the cheapest and we all know it's good so that's what I use most.
The Following User Says Thank You to GearheadSS For This Useful Post:
1BADZ28 (03-04-2022)
