Go Back   The Supercar Registry > General Discussion > Ford-Mercury
Old 01-07-2022, 03:01 PM
msclassiccars's Avatar
msclassiccars msclassiccars is online now
Default "K-Code" 1965 Ford Falcon
Pretty interesting read from Hemmings.
https://www.hemmings.com/stories/202...-compact-sedan
"Ford’s early Falcon-based Mustang had plenty of power available—not least of which was the legendary "K-code" 271-hp 289-cubic inch V-8. A solid-lifter cam, 10.5:1 compression, special heads with smaller combustion chambers, low-restriction exhaust manifolds, 2-inch dual exhausts with a crossover pipe and low-restriction mufflers, beefier main bearing caps, and a carburetor that flowed 595 cfm were the hard parts that got the performance nuts drooling. But the package was much more: it also included a dual-point, centrifugal-advance distributor, Autolite BF32 plugs, a water pump with fewer vanes, a fuel pump with an extra spring, a larger-diameter alternator pulley, and a special four-blade cooling fan, as well as larger-diameter rod bolts and a counterweighted crankshaft, all to help the K-code mill rev to its 6,000 rpm redline repeatedly without issue. A chrome dress-up kit belied the seriousness of the package. No power steering, power brakes, automatic transmission, or air conditioning could be specified with the 271 hp engine in 1965; there was only a Toploader four-speed and a 9-inch rear filled with a series of increasingly hairy gearsets, clear up to 4.11:1. Such were the guts of Ford’s Hi-Po package, as it became known.
Despite shared mechanicals, Ford refused to drop the K-code 289 into Falcons—doubtless so it could keep pumping out pony cars by the gross. But Ford of Canada, whose assembly line pumped out Falcons rather than Mustangs, announced that the K-code engine was available in all Falcon models, except station wagons, sold in Canada for the 1965 model year. Per a letter sent to the NHRA’s National Dragsterby Ford Motor Company of Canada, all were equipped with the Toploader four-speed, heavy-duty suspension, 10-inch drum brakes, and Traction-Lok, which was unavailable even on ’65 Mustang K-codes. All would be special orders, and indeed research indicates that a total of seven were built through the end of July, 1965. Seven. This is one of the seven."
Marc Schiliro
MS CLASSIC CARS
www.msclassiccars.com
The Following User Says Thank You to msclassiccars For This Useful Post:
Lee Stewart (01-07-2022)
Old 01-07-2022, 04:49 PM
tom406 tom406 is offline
Rankin’s “Wild Child” was one of the K codes when new: https://www.hemmings.com/stories/201...ads-to-auction
The Following User Says Thank You to tom406 For This Useful Post:
msclassiccars (01-07-2022)
Old 01-07-2022, 05:00 PM
Ryan1969Chevelle's Avatar
https://www.motortrend.com/features/...-falcon-hi-po/
Teachers Pet lives near me.
Ryan W31.
Old 01-10-2022, 05:17 PM
RALLY RALLY is offline
That 289 motor could rev and these cars were fast back then.
Old 04-21-2022, 11:43 AM
EZ Nova EZ Nova is offline
I looked at a OG K-code Falcon YEARS ago. This car was black with red int, 4 spd and factory 4.30 gears. I also seen a white with red one as well.
I was fortunate to have a local FACTORY Ford racer by the name of Don Henderson. He was racing factory cars back in those days and HIS story matched to what the second owner that said there was a lot more then 7 made, a lot more. Now Don said that Ford made almost enough for every other Ford dealer in Ontario to get a car. NOT every Ford dealer would get one. He said there was more then 40 made that he was aware of???
Both Don Sr and Jr passed away years ago so we can't get more info from them. He was racing a 66 427 Fairlane and a factory Paxton car as well.
Don Sr. was also the man who found an original GT350 COUPE. He restored that car, took it to a Shelby show where everyone claimed it was a fake. That is till Carol himself confirmed they made a few of them. NO ONE in the know of Shelby's knew that the GT3550 COUPE existed. But Don did and found one. So I would take it that he knew his Fords.
'78 Z28 4sp being restored
'70 W30 convert TRIBUTE
'66 CANADIAN Nova SS Race Car
'69 FIREBIRD Tubbed Racecar
Old 04-21-2022, 11:50 AM
Marc, also, I don't think FORD sent the letter to NHRA claiming 7 were made? That was R. Daigneault of Tibury Ontario. Now maybe that was a local dealer that sent that? I don't know, but I don't think Ford officials were from Tilbury? Maybe oakville, Windsor or St. Thomas, but never heard of anyone of the Ford people from Tilbury? But this was also before I was born.
https://www.motortrend.com/features/...f-6354a11f9a72
Old 04-21-2022, 12:55 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Ryan W31.
Nice one for the MCACN Canadian display Ryan
I ain't nobody, dork.
The Following User Says Thank You to Tracker1 For This Useful Post:
Ryan1969Chevelle (04-22-2022)
Old 04-22-2022, 01:32 AM
I’ll reach out to the owner.
Ryan W31
Tracker1 (04-23-2022)
Old 04-24-2022, 11:47 AM
Here is a bit more info. Seems Mercury offer a 1965 Comet 202 with the 289 271Hp K code cars and actually built 2 from the factory as it seems it just a easy thing to do. It was Ford version of COPO, Ford was call DSO for Domestic Special Order. So eve thought there were not "offered" from the factory with a K-code engine, DSO could make it happen, and sounds like they did.
https://www.motortrend.com/features/...sole-survivor/
Old 05-11-2022, 02:02 AM
Those 65 K code 289 were high revving short stroke engines. Very quick. 289's were a nice engine.
Tags
289, falcon, ford, hipo, mustang
