Old 06-18-2020, 03:04 AM
Originally Posted by flyingn View Post
I have a 22' + 3' v nose all alum trailer by Ligntning which is owned by Forrest river industries. Its light as heck and hauls my 3800 lb car with ease with my f150. I had it custom made with the man door moved up away from the car and the escape door also moved up so that I can fully open the car door to get out. I have a rubber floor, white walls, 5200 lb axles, alum wheels, heavy duty frame, in floor e track, beavertail and a few other options. Very inexpensive. $11000 delivered 500 miles. It pulls like a dream. https://www.lightningtrailers.com/pr...270&Image=9886
Looks near Identical to our custom ordered trailer - 22ft with a 3 foot V, double fold down ramp with check plate double fold - all rubber check floors, white finished roof and walls, we have a set of cabinets up high in the V and our ceiling is 8ft to accommodate our 1940 FORD Woodie Wagon which is pretty TALL - it also has built in jack stands on the rear corners so you can load/unload with out it being attached to a truck.
We have the Reese sway control and load levelers... the SWAY control was a LIFE SAVER last year when I was on the way back from the Cinci NCRS Regionals there were 50 MPH gusts when I came down through Fancy Gap and the truck and trailer were taking alot of side winds.
Weighs 5500
Cost right at $14,500
Pulling with a Duramax GMC.
FWIW the woodie wagon has never been in the trailer... it's been driven near 30,000 miles since being restored.
Old 06-18-2020, 01:10 PM
L16pilot L16pilot is offline
Just ditched my Reese weight distribution hitch for the Andersen. It's simpler, lighter and offers built in sway control. Used it a few times and so far, I like it much better than the traditional WD hitches....worth a look.
Steve Nuwer
1970 Z28, Norwood 03A, 48 48, 723 Int, M20, COO, 2021 Legends Platinum restored
1970 L78, Norwood 04C, 17 17, 711 Int, M21, COO, born-with drivetrain project.
1972 Z28, Norwood 11C project, born-with drivetrain, 26 26, 775, M20, CGG project
1970 Z28, Norwood 05C, 48 G, 720 Int, M21, COZ, Original Unrestored (SOLD)
www.2ndGenZ.com
Old 01-17-2022, 04:28 PM
flyingn's Avatar
flyingn flyingn is offline
Originally Posted by muscle_collector View Post
very nice looking trailer. have you ever weighed it empty?
3000 lbs
Frank Szymkowski
Old 01-17-2022, 07:53 PM
Richls5's Avatar
Richls5 Richls5 is offline
3000 lbs
I saw you said you paid 11k for it how long ago? I’m looking into atc and they’re 24-36k used ones aren’t much cheaper I wanted to spend under 15 but doesn’t seem like that will be the case
Old 01-17-2022, 11:05 PM
Rich, this is local to me, but you may be able to find a dealer closer to you with a similar price. Nothing fancy, but spankin' new and has an escape door for under $15k
https://www.marvstrailersandautos.co...erset-WI-54025
Old 01-17-2022, 11:50 PM
R68GTO R68GTO is offline
I did a bunch of looking myself and eventually ordered a CarMate trailer. 8.5 x 24 with escape door, rubber coin floor, white laminate walls and ceiling, aluminum wheels, 6,000 lb axles, e-track from to back. It is about $18,500 with these options. Looked at ATC, nice for sure but couldn't justify the extra $10-12K for the lighter weight since I'll probably only use it it 10-12 times per year.
Won't get it until April, but feel lucky at that. Others that I looked at were quoting 12-14 months delivery.
Old 01-18-2022, 12:06 AM
Richls5's Avatar
all of the dealers around here say on order i'll start calling around see what the wait will be
Old 01-18-2022, 02:34 PM
dustinm dustinm is offline
Ive been putting off buying a trailer for a few years but I followed the market and have noticed trailers have went up 50% in the last year. I am too cheap to pay the extra now so I am going to wait and see if the bottom falls out.
Old 01-18-2022, 07:15 PM
Donnie's Avatar
Donnie Donnie is offline
heres a pic of my 2015 Wellscargo
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 01-18-2022, 09:37 PM
Cost of steel and aluminum accounts for a lot of that increase. Labor some too, as many manufacturers have had to raise wages to attract workers.
