Old 02-09-2022, 12:14 AM
Default How do you translate original fuel pump dates?
How can I tell the dates on some used fuel pumps I have? If I remember correctly these two came off original Big Block 1969 & 1970 Chevelle's. Any help would be appreciated.
Bill
Attachments - The Supercar Registry fuelpump4web.jpg Fuel Pump dates.jpg Fuel Pump Dates - 2.jpg Fuel Pump date codes.jpg
Old 02-09-2022, 03:43 PM
referencing a search on this site, I believe the 016H to be the 16th day of 1968, but I can't figure out the 249U? I remember them to be off of L-78 engines I had. Any input would be appreciated.
Bill
Old 02-09-2022, 03:55 PM
X66 714's Avatar
X66 714 X66 714 is online now
I got this from CRG...Joe
GM in the 60s had a 2 letter code where the first letter was the month A=Jan,B=Feb and so forth and the second letter represented the year, H=68, I=69,J=70
Starting in 71 the Julian date replaced the 2 letter. So 1=jan1st & 365= Dec 31st and all points in between. The Letter after the number, the year, still followed in order of previous, J=70, K=71...N=1974
Old 02-09-2022, 07:20 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Joe has it. I have an original assembly line 68 350hp fuel pump. I’ll send a photo later tonight if I don’t forget. If you want to see it but what Joe shared is correct.
Old 02-09-2022, 08:25 PM
jdv69z's Avatar
jdv69z jdv69z is offline
Original Fuel pump from my Oct 68 69 Z/28
Jimmy V.
The Following User Says Thank You to jdv69z For This Useful Post:
X66 714 (02-09-2022)
Old 02-10-2022, 02:49 AM
So U would be 1983?
Old 02-10-2022, 03:08 PM
Thanks for the picture. Am I reading this correctly as HH40669? (August 1968)
Bill
Old 02-11-2022, 12:29 AM
169indy's Avatar
169indy 169indy is offline
The 1/16" tall (aka Small) lettering are from later replacement pumps. Examples of Vintage Factory pumps have the Larger 1/8" lettering.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following User Says Thank You to 169indy For This Useful Post:
Big Block Bill (02-11-2022)
Old 02-11-2022, 01:53 AM
MJV1953 MJV1953 is offline
Default I got this off another website regarding date codes
Hope you can read it.
The Following 2 Users Say Thank You to MJV1953 For This Useful Post:
Big Block Bill (02-11-2022), mhm1966 (02-12-2022)
Old 02-11-2022, 01:35 PM
jdv69z's Avatar
Bill
Yes
Jimmy V.
