Old 02-15-2022, 07:27 PM
X66 714's Avatar
X66 714 X66 714 is offline
Looking good. Keep cruisin'....Joe
169indy (02-15-2022)
  #22
Old 02-18-2022, 03:35 AM
169indy's Avatar
169indy 169indy is offline
Default Front & Back Panels
My Painter Jeff R. did a great job, I then polished the corner stainless steel trim Vintage Logo from VIC's66. Both panels required "body" work & weld repairs to get them into usable condition.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following 3 Users Say Thank You to 169indy For This Useful Post:
PeteLeathersac (02-18-2022), X66 714 (02-18-2022), Xplantdad (02-18-2022)
  #23
Old 02-18-2022, 10:52 AM
X66 714's Avatar
They look wonderful....Joe
169indy (02-18-2022)
  #24
Old 02-18-2022, 05:12 PM
169indy's Avatar
Thanks Joe, More progress soon. I can't wait to Pose it with a car or ten,,,,LoL
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following User Says Thank You to 169indy For This Useful Post:
  #25
Old 03-02-2022, 02:28 AM
169indy's Avatar
Default Window Glass
Worked on the upper access door glass, local glass provider supplied new cut and radius glass, Decal found on line, Rubber channel Trimmed then installed with Wayne glass channel plastic guides and steel retainers.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following 5 Users Say Thank You to 169indy For This Useful Post:
napa68 (03-14-2022), olredalert (03-02-2022), PeteLeathersac (03-02-2022), X66 714 (03-02-2022), Xplantdad (03-02-2022)
  #26
Old 03-14-2022, 04:33 PM
169indy's Avatar
Default Fuel-flow rotary indicators
When I got the pump it was missing the premium fuel flow indicator, So I used Dad's old Atlas lathe and cut down some 1/4" sheet plexiglass & brass rod to Fab a likeness attempt. Missed the mark on a few details but It is hidden by the pump Computer facade and very little is visible. It will work for now.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following 4 Users Say Thank You to 169indy For This Useful Post:
COPO (03-15-2022), napa68 (03-14-2022), PeteLeathersac (03-14-2022), X66 714 (03-14-2022)
  #27
Old 03-26-2022, 07:54 PM
169indy's Avatar
Smile Hose & Upper Doors Installed
Got the Six foot display gas hose hooked to retractor and a $15 Portland Swap meet Nozzle. I had to replace the Back side upper door with a stainless steel replacement, I had a earlier steel-plated and bent so I source a replacement item from Used Parts Vendor with the New glass & decal after time on the Polishing wheel and rubber trim, it is surely getting there.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 03-26-2022, 08:13 PM
X66 714's Avatar
Lookin' Great. I need to do a few more of mine...Joe
169indy (03-26-2022)
  #29
Old 03-26-2022, 08:54 PM
ruralrte66 ruralrte66 is offline
Looks Awesome, Great Job!!
The Following User Says Thank You to ruralrte66 For This Useful Post:
  #30
Old 04-21-2022, 01:54 AM
169indy's Avatar
Finished; Mounted the Veeder & Root Computer, Front Facia reveals, Internal Switch.
Done
Poll: Globe Modification or Not<?>
JIM
*Note: The Computer was Solid with critter and hornet MESS, resulting in a rusted solid works. Impossible to animate with dual external dc motor drives to make the pump indications operational. I SO wanted to rig a set up that would display & learn the computer op's. Static it Remains.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
NorCam (04-21-2022), ORIGLS6 (04-26-2022), SuperNovaSS (09-10-2022), X66 714 (04-21-2022), Xplantdad (04-21-2022)
