Old 02-07-2022, 01:22 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is online now
No install this weekend as the valve did not show up - patience grasshopper.............
Jake Dykstra
Dykstra Motorsports
Xplantdad (02-07-2022)
  #82
Old 02-07-2022, 08:25 PM
RPOLS3's Avatar
Look what showed up today - now just need to find some time to install.
Jake Dykstra
Dykstra Motorsports
The Following 6 Users Say Thank You to RPOLS3 For This Useful Post:
1972convss454 (02-08-2022), 69M22Z (02-07-2022), dykstra (02-08-2022), napa68 (02-07-2022), olredalert (02-08-2022), Xplantdad (02-10-2022)
  #83
Old 02-08-2022, 12:59 AM
dykstra's Avatar
dykstra dykstra is online now
Will work for beer!!
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
RPOLS3 (02-08-2022)
  #84
Old 02-08-2022, 02:20 AM
67since67's Avatar
Hope it works out this time!!
RPOLS3 (02-08-2022)
  #85
Old 02-08-2022, 02:22 AM
1972convss454 1972convss454 is offline
Say What One More Time!
It's going to work this time. You always have to do things at least three times. Nothing can ever be easy.
Joseph Farrow
1970 Chevelle L78
1970 Chevelle LS6
1972 Chevelle LS5
The Following 2 Users Say Thank You to 1972convss454 For This Useful Post:
dykstra (02-08-2022), RPOLS3 (02-08-2022)
  #86
Old 02-21-2022, 01:29 PM
RPOLS3's Avatar
Found a small window of time to get the rebuilt valve installed this weekend, letting it gravity bleed now and we'll go from there.......small steps.
Jake Dykstra
Dykstra Motorsports
67since67 (02-22-2022), dykstra (02-22-2022), napa68 (02-21-2022), olredalert (02-21-2022), PeteLeathersac (02-21-2022), scuncio (02-21-2022)
  #87
Old 02-21-2022, 10:29 PM
napa68 napa68 is offline
Baby steps are an excellent way of NOT testing your sense of humor!
The Following 2 Users Say Thank You to napa68 For This Useful Post:
67since67 (02-22-2022), RPOLS3 (02-22-2022)
  #88
Old 02-22-2022, 01:12 AM
RPOLS3's Avatar
My baby steps last night along with Bill's thread on the progress of his '67 wagon motivated me to get out in the garage tonight and get something done - or at least make some more progress. Wasn't having much luck with the gravity bleeding so I started pumping the pedal and was able to get fluid to all four corners with no apparent leaks in the rebuilt valve so far - so tomorrow night when my wife has some time to help she will do the pedal pushing on what I'm hoping is the final brake bleed.
Earlier when assembling the rebuilt engine accy's I noticed my smog pump pulley was not running true. Previously I had the pump installed with the pulley off and a shorter belt which worked because the cooling blades on the perimeter were worn off from belts slipping off over the years (hence me using a bypass belt) and nothing interfered - so I never noticed the pulley wobble as I ran without one for the last 20+ years. The rebuilt smog pump has a correct and un worn fan with proper cooling blades which now interfere with the shorter bypass belt so that is not an option, plus the new pump is de-vaned inside anyways so I have no reason to bypass it. After a quick check with Mr. Hodel he assured me the pulley was the issue. I found a correctly numbered one on e-bay - took a chance and bought it and cleaned it up over the weekend and checked it tonight - much better now. So the smog pump and related went back on which allowed me to finish the install of the fan and shroud as well. I also found the correct length belt in my spare stash in the trunk after Quanta sent me one that was too short - so now I know the correct length to order a replacement. One last coat of paint on the new smog pulley and that will be all buttoned up as well and ready to fire up.
Getting closer now - hopefully no more setbacks. Feels good to be this close with Spring right around the corner here in Northern IL.
Jake Dykstra
Dykstra Motorsports
The Following 4 Users Say Thank You to RPOLS3 For This Useful Post:
dykstra (02-22-2022), napa68 (02-23-2022), olredalert (02-22-2022), Xplantdad (02-22-2022)
  #89
Old 02-22-2022, 01:23 AM
It's still a couple months before the roads are clean of salt, so you've got plenty of time. It's going to be great, Jake...
RPOLS3 (02-22-2022)
  #90
Old 02-22-2022, 02:42 AM
67since67's Avatar
Jake, your second paragraph, sounds like something I could have written myself!! Solving one problem exposes another, and then eventually circles back, working details along the way, and in the end all good!
Dealing with the challenges along the way makes the end result more satisfying!
Bleeding brakes, once you have fluid pushing out of all four they should gravity bleed easier. Just do one corner at a time, and patience!!
Bill W
The Following 4 Users Say Thank You to 67since67 For This Useful Post:
dykstra (02-22-2022), kwhizz (02-22-2022), L78_Nova (02-23-2022), RPOLS3 (02-22-2022)
