Old 02-21-2022, 06:40 PM
mhm1966 mhm1966 is offline
Default 1969 Camaro Sill Plates
From my understanding you cannot restore original still plates that have the rivets for the Fisher Body emblem. So, who is making the most accurate reproduction sill plates? I sure would like to use my originals because they are in good condition, but I feel they need something to look like they did when they came out of the factory.
Attachments - The Supercar Registry IMG_2616.jpg IMG_2615.jpg IMG_2613.jpg IMG_2602.jpg
Old 02-21-2022, 08:25 PM
Zman1969 Zman1969 is offline
Hearbeat has them listed as concours quality
https://www.heartbeatcitycamaro.com/...644760-USA%21/
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
The Following User Says Thank You to Zman1969 For This Useful Post:
mhm1966 (02-22-2022)
Old 02-21-2022, 11:34 PM
Unreal Unreal is offline
I don't see why not. I bought a lot of maybe 20 sill plates in generally bad condition at a swap meet, because a few had near-pristine Fischer Body emblems. I ground off the back of the rivets, and installed the original Fischer emblems on newer NOS sill plates. I just drilled out the sill plates, and epoxied the remains of the original rivets from the back side.
I don't see why you couldn't remove the Fischer emblems, similar to how I did, polish the sill plates, and then reinstall the emblems
The Following User Says Thank You to Unreal For This Useful Post:
Old 02-22-2022, 12:13 AM
That is what I was thinking of doing but wanted to get some input on how to restore them. Is the finish supposed to be satin or shiny? Getting back to the reproductions, I do not see any difference in HBC sill plates compared to OER except for the price. They both have the rivets.
Old 02-22-2022, 03:39 PM
wthirty1 wthirty1 is offline
I did something similar on mu '70 Cutlass prior to MCACN this past fall. The NOS sill plates didn't have the rivets.
I put a piece of tape over the front of the Fisher Body tag on my factory plates since the rivet is so tiny and I didn't want to risk losing it.
I took a grinding wheel to the back side of the plate to get the rivet loose.
Pulled the rivet out and kept it in a safe spot until I drilled a hole in the NOS plates.
The smallest dab of super glue and some tweezers helped get the factory rivet in to the NOS plates.
1970 Cutlass S W-31 - platinum, blue stripes, blue buckets, M14 3-spd
1970 Cutlass Supreme Y74 Pace Car #79
1970 Rallye 350 - automatic, original paint survivor
The Following 2 Users Say Thank You to wthirty1 For This Useful Post:
mhm1966 (02-22-2022), olredalert (02-22-2022)
Old 02-22-2022, 03:41 PM
Default Finish plate
This is an NOS sill plate with the factory rivet removed from the original plates and installed in the NOS plate.
Old 02-23-2022, 10:12 PM
IF not mistaken The Aluminum sill plates are clear anodized originally.
olredalert (02-24-2022)
Old 02-24-2022, 05:05 PM
Kurt S Kurt S is offline
That's what I recall too....
Kurt S - CRG
Old 02-25-2022, 12:30 AM
70post 70post is offline
Yes - they are Bright Dip Anodized...a different process compared to regular clear anodizing. Extremely hard to redo nicely on a door sill plate where there are all the little ridges, nooks and crannies. Best bet is as mentioned above...install original rivets on NOS plates.
Patton Glade
70Post Restorations
Austin, TX
The Following User Says Thank You to 70post For This Useful Post:
mhm1966 (02-25-2022)
Old 02-25-2022, 06:36 PM
I had believed the sheets were probably anodized prior to stamping, just like most zinc parts were plated as blank sheets and then stamped, same with the fuel tanks etc.
