Old 03-31-2022, 03:19 PM
Mark2002 Mark2002 is offline
Does anyone have Jerry B's ID? I would like to message him about his Chevelle 4.56 gear. Or please ask him to write to me? Thanks.
Some pics for your viewing pleasure....
The Following 5 Users Say Thank You to Mark2002 For This Useful Post:
chevyman0429 (03-31-2022), jbtech (04-07-2022), L_e_e (04-11-2022), Oldss (04-01-2022), PeteLeathersac (04-11-2022)
  #12
Old 03-31-2022, 06:57 PM
tunes's Avatar
tunes tunes is offline
That looks pretty good! Keep those pictures coming.
Robert
_______________
2023 Stingray Coupe Z51
Old 04-11-2022, 05:10 PM
RPO LS7 RPO LS7 is offline
https://newjersey.craigslist.org/pts...466754148.html
John
The Following 2 Users Say Thank You to RPO LS7 For This Useful Post:
Oldss (04-12-2022), PeteLeathersac (04-11-2022)
  #14
Old 04-11-2022, 09:03 PM
scuncio scuncio is offline
That's a very cool project!
Old 04-12-2022, 05:29 PM
Originally Posted by Mark2002 View Post
The build sheet has a XF code crossed out and XD written in. Seems strange that they would replace an M21 with another M21 code. A friend suggested to me that perhaps it was meant to be replaced with a M22. The transmission is in the car, so I haven't been able to verify the shaft or the angle on the gearing to confirm it as an M21 or M22.
I have not driven it yet which would make it much easier to tell which trans.
Unfortunately, it no longer has the original motor. The sheet metal appears to be all original and in great shape. Surprisingly for a NJ car, it has original quarters rockers and fenders. Floors and trunk are also very good. I'll post some pictures soon.
The trans change was probably related to the driven gear in the trans speedo bullet. They had to get the speedo to the correct speed based on the rear ratio, the driven gear on the bullet, and whether or not a Stewart Warner reducer was needed.
ScottG (04-23-2022)
  #16
Old 04-14-2022, 05:29 AM
ZiggyL78's Avatar
ZiggyL78 ZiggyL78 is offline
Hello, new member here, I've been reading the forum for a while and just joined.
I have a 1969 Chevelle L78 4 speed originally Butternut yellow. Black top, black interior.
My build sheet has a KM code which matches the stamp on the rear for a 4.56 gear. All the sources I can find on the web point to only one 1969 Chevelle ordered with this rear end ratio. Does anyone else out there have a documented factory 4.56 rear in their car?
Thanks
Hi Mark. I am fairly sure that my 69 Chevelle Sedan Post had factory 4.56 gears. I will have to dig through my albums to see if I still have the GM docs on the car. The only reason I remember is that I was disappointed that someone had changed the gears to a highway set and I had to install the 4.56 gears as I was trying to get the car back to stock. I would be really surprised that it was that rare an option as most guys that ordered an L78 knew the car would not work without a serious gear. I remember that gear was real popular back in the day and 70% of my friends had that gear. If you had a hi revving SBC you could go for 4.88s but with a stock BBC 4.56 was about perfect. I'll get back to you if I find the paperwork. Ken
Real Canadian Rock
https://www.youtube.com/watch?v=Zdeo-i6uw5g
The Following 2 Users Say Thank You to ZiggyL78 For This Useful Post:
Ralph Spears (06-09-2023), Ryan1969Chevelle (04-14-2022)
  #17
Old 04-15-2022, 09:31 PM
Kurt S Kurt S is offline
And you're looking for the VIN for your old 69 Camaro too.
Kurt S - CRG
Old 04-16-2022, 02:22 AM
My old 68 chevelle L78 M22 with 4.88 gears was last in Chicago. Any body see it ? Grotto blue. White buckets.
Old 04-18-2022, 06:56 PM
If it was a different speedo gear required because of the rear end ratio, would that have a different transmission code on the build sheet? Are there any other difference between a XF and a XD?
Old 04-18-2022, 09:42 PM
GrumpyJeff's Avatar
GrumpyJeff GrumpyJeff is offline
Any pics of this car ???
The Following User Says Thank You to GrumpyJeff For This Useful Post:
albi (04-23-2022)
