Old 04-23-2022, 03:27 PM
mrays mrays is offline
This Gunmetal Gray 71 Charger R/T 440 Six Pack is a TorqueFlite car that used to be part of Tim Wellborn's collection. According to the auction write up this car still has its original engine and is documented with two build sheets. It sold for $58K.
The Following 6 Users Say Thank You to mrays For This Useful Post:
69M22Z (05-01-2022), Dave Rifkin (04-23-2022), L78_Nova (04-25-2022), markinnaples (04-25-2022), olredalert (04-23-2022), PeteLeathersac (04-25-2022)
  #1202
Old 04-23-2022, 03:33 PM
This Curious Yellow 71 Cuda is a TorqueFlite car with 4.10 gears. It was bid to $105K. It later sold at Kissimmee in '21 for $150K.
  #1203
Old 04-23-2022, 03:40 PM
This Curious Yellow 71 Cuda convertible is 1 of 17 built and was sold new in Shaker Heights OH to Ed Suit. As you can see by looking at the fender tag the Billboards, Shaker hood, Go Wing and Rallyes were all added to the car when it was restored. This car was featured in the February '13 issue of Mopar Action. This car was bid to $700K.
  #1204
Old 04-23-2022, 03:46 PM
This Tor Red 71 Cuda convertible is 1 of 17 built and was an export car when new. As you can see by looking at the fender tag the Billboards and Shaker hood were added to the car and don't match the patina of the rest of the car. This car is documented with a build sheet. It was bid to $325K.
The Following 4 Users Say Thank You to mrays For This Useful Post:
  #1205
Old 04-23-2022, 03:54 PM
This Rallye Red 71 Cuda convertible is 1 of 17 built and has a column shifted TorqueFlite with 4.10 gears. This is an original drivetrain car that once belonged to Steve Juliano. This car was just on display and didn't run through the auction. It sold for $1.05M at Mecum Indy in '19 and for $875K at Mecum Kissimmee in '21.
The Following 5 Users Say Thank You to mrays For This Useful Post:
  #1206
Old 04-23-2022, 03:59 PM
This Rallye Red 71 Hemi Cuda is a 4 speed car with 4.10 gears. As you can see by looking at the fender tag this car didn't come with Billboards either. Very few 71 Cuda's came from the factory with Billboards, but a lot of cars have had them added when they were restored. This car was bid to $400K.
  #1207
Old 04-23-2022, 04:05 PM
This In Violet 71 Hemi GTX is 1 of 32 built and was sold new at Queen City Motors in Sedalia MO. It is a 4 speed car and is documented with a build sheet. It was bid to $250K.
The Following 7 Users Say Thank You to mrays For This Useful Post:
69M22Z (05-01-2022), Dave Rifkin (04-23-2022), L78_Nova (04-25-2022), markinnaples (04-25-2022), olredalert (04-23-2022), PeteLeathersac (04-25-2022), Tenney (04-26-2022)
  #1208
Old 04-25-2022, 03:52 PM
Thanks again for all of the amazing pictures!
1968 Camaro Ex-ISCA Show Car
John 10:30
Old 04-26-2022, 12:24 AM
Ditto on the thanks!!
Knowing nothing at all about Mopars, seeing all those different fender tag attachments I just have to ask, which is correct -
- Neither screw painted body color, both screws black
- Neither screw painted body color, both screws plated
- Both painted body color
- One painted body color and one black (and if so which side is painted and which is black)?
- One painted body color and one plated (and if so which side is painted and which is plated)?
I think there is at least one of every scenario in those pics!!
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
The Following User Says Thank You to jeffschevelle For This Useful Post:
markinnaples (04-26-2022)
  #1210
Old 04-26-2022, 12:29 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Depends on whether it was a two tag car or not. Typically the screw closest to the front of the car should have paint as its first tag was attached during paint and the corner often bent up awaiting paint underneath and the second tag, further out the line. That second tag would often be attached with a paintless screw.
But nothing is consistent with Mopars - nothing.
I ain't nobody, dork.
