Old 05-22-2022, 02:05 PM
scuncio scuncio is offline
Default '68 327/4-sp Malibu
Interesting to see a '68 Malibu with a 327/4-sp and radio delete. Totally worthless auction description, but it might be a L-79, who knows. VIN is also incorrect - should be a 136xx....
Definitely no bargain at the $37k opening bid, but may be closer to a realistic number if it were a #s 325hp car.
Link to 1968 327 Malibu auction
137378Z137364
The Following 3 Users Say Thank You to scuncio For This Useful Post:
69 Post Sedan (05-23-2022), L78M22Rag (05-24-2022), markinnaples (05-23-2022)
Old 05-24-2022, 03:40 AM
You’re right, the description is useless and so are most of the pics. I like that factory pinstripe! Parts of the car look unrestored. There’s some rash on the front bumper… I wonder what’s original and unrestored? 6k tach… hmmm
Old 05-24-2022, 04:05 AM
Isn't that a '69 tach/gauge cluster ? '68 should have the roller tach. Mine did.
Old 05-26-2022, 08:04 PM
That’s a good point, it should have a roller in the center. I shoulda caught that!
A ‘69 Chevelle tach setup is round and has the other gages at N, S, E & W. This one is square and has the gages in the NE, SE, SW and NW corners?
Old 05-26-2022, 08:35 PM
That's a standard 68 idiot light dash cluster and someone has added an aftermarket 'factory-look' tach in the center of the right hand gauge pod. Correct about the roller tach, if it had been a true factory setup, it would have gages in the place of the idiot lights plus the roller tach directly above the steering column.
Bill Pritchard
dustinm (05-27-2022)
Old 05-26-2022, 11:13 PM
67since67's Avatar
Thinking that the tach is placed in the factory clock location?
No pix with the hood or trunk open?? Might be a nice car...but, using terms like unmolested, unaltered, true time capsule, survivor, 100% original... and seeing a fresh gas tank, fresh orange oil pan paint, and headers, (failed mention that with the flow master), description is in doubt.
The Following 3 Users Say Thank You to 67since67 For This Useful Post:
dustinm (05-27-2022), dykstra (05-27-2022), L78M22Rag (05-27-2022)
Old 05-27-2022, 03:22 PM
My 68 El Camino has no clock and no tach, and no gauges, other than fuel. I thought about a hood tach. I hate the roll tach; and they are expensive.
Also thought about cutting a hole in the cluster where the clock would be on a 68. Looks to me like that is exactly what was done on this one.
Old 05-27-2022, 08:08 PM
Does anyone repro the roll tach, or would you have to find a used OEM piece?
Bill Pritchard
Old 05-27-2022, 08:44 PM
Repro is $209 and some change.
Originals bring in excess of $600.
Bill Pritchard (05-28-2022)
