Old 05-28-2022, 02:26 AM
ALLZS ALLZS is offline
Default Corvette wipers
my 66 corvette wipers will not turn off just keep running ???
Old 05-28-2022, 02:47 AM
TimG TimG is online now
I had that happen during NCRS judging, I lost full operations points for my wipers.
There's a small lever inside of the wiper mechanism and the grease in the mechanism may get hard and not allow the lever to turn off the wipers. You can unplug the wires from the on/off switch, and it will still stay on. The wiper mechanism probably needs to come out and be serviced.
randy27 (05-31-2022)
Old 05-28-2022, 11:56 AM
napa68 napa68 is online now
The switch controls the ground. If you disconnect the switch, do they stop?
Tim
Old 05-28-2022, 12:13 PM
My experience is you have to pull the power wire from the wiper motor. The dash switch is out of the loop once the motor is stuck in the on position.
Old 05-28-2022, 02:21 PM
no I replaced the dash switch also if I unplug the switch the motor keeps running also like its stuck in low speed
Old 05-28-2022, 04:33 PM
What Tim Gilmore said should be the problem.
EPL (06-01-2022)
Old 05-31-2022, 03:50 AM
randy27 randy27 is offline
That's unfortunate.
We'll check this Corvette tomorrow which having the same issue intermittently. It is in the shop for the installation of new tires from 4Wheelonline plus the alignment. The owner said his son to replace the switch but it still happens.
Old 05-31-2022, 12:51 PM
I am removing the motor today
