Old 07-16-2022, 10:23 PM
Default Pulse technology battery charging
Check out Post #17 in this thread.
Kurt mentioned a pulse technology charger from this company:
https://www.pulsetech.net/store/12v-...ce-system.html
I really don't need a 12 station charger (on second though, maybe I do).
Was wondering if this is really that much better for long term trickle chargers, as well as bringing back a sulphated battery.
Old 07-17-2022, 03:16 PM
napa68 napa68 is offline
It works!!
I find the batteries last much longer with the pulse chargers and yes, they can revive some batteries as well.
Tim
Old 07-17-2022, 04:04 PM
Thanks.
Found that same model on Ebay brand new for $139.
Old 07-17-2022, 05:10 PM
Billohio Billohio is offline
I have one of the pulse chargers and seem to work well
Bill
Old 07-18-2022, 12:53 AM
I have a 2 battery Battery Tender and rotate it between 6 batteries all winter. This might be a nice addition.
Old 07-18-2022, 01:30 AM
https://www.ebay.com/itm/265760477038?autorefresh=true
I offered $122. He countered at $139.99; and I accepted.
Old 07-18-2022, 03:20 AM
Lynn, do you have it yet ? I went back and read more and am a little confused. It says it can charge 12 batteries at a time, but the pic shows only 3 sets of cables coming from 4 ports ?? By reading more, I assume each port charges 3 ? Strange pic then, indicating a person would get enough cables to charge all 12.
Old 07-18-2022, 01:12 PM
Was wondering the same thing. Figured I was still OK if it will only handle four. I suspect they want you to tie three together some way and that each set of clips can handle up to three batteries.
I have tied two together (and one of my British cars has two 12v batteries connected in parallel) and used a trickle charger before and that works fine.
Will post a pic of the instructions when it gets here.
Old 07-18-2022, 01:28 PM
Old 07-18-2022, 01:58 PM
https://www.pulsetech.net/media/wysi...ro12Manual.pdf
