Old 10-14-2022, 01:39 PM
Zman1969 Zman1969 is offline
Originally Posted by Edgemontvillage View Post
"Cool and I forgot to look on CRG -older age is great isn't it? -I found the thread there, was hoping for some measurements of through bolt spacer and washer if its handy? I have also reached out to Lloyd Edgemont as he was looking I'm pretty sure he has located it by now
Mike (rszmjt) is your best source for the measurements on those second design mounts as I have the first design (and they're now installed on the car).
Lloyd.[/QUOTE]
Thanks Lloyd! Im going to ask your unanswered question here from the CRG thread
1. Length of the through bolt
2. Diameter and thickness of the flat washer (it appears to be extra thick)
3. Inside and outside diameters of the bright sleeve that passes through the motor mount stop bracket (best view is the first photo)
my car is a Sept 69 built car
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 10-14-2022, 04:43 PM
rszmjt rszmjt is offline
OK, I found them , had to dig through quite a few big totes as they were in storage, sorry for the delay.
Thick washer - 1.380 OD
- .187 thick
Spacer - .875 OD
- .565 thick
Through bolt is - 4.450 bolt length underhead to tip
TR head marking with 6 slashes.
Hope that helps.
Cheers. Mike
The Following User Says Thank You to rszmjt For This Useful Post:
X66 714 (10-14-2022)
  #13
Old 10-14-2022, 06:39 PM
- .187 thick
Spacer - .875 OD
- .565 thick
Hope that helps.
Cheers. Mike
Great thanks Mike!! I borrowed link to pic of the mount assembled
90 Formula 350
