Old 10-14-2022, 04:53 PM
BLACKLS5 BLACKLS5 is offline
Looks Dyn-O-mite Sir. I love Forest green.
The Following User Says Thank You to BLACKLS5 For This Useful Post:
L78_Nova (10-14-2022)
  #182
Old 10-14-2022, 05:14 PM
L78_Nova's Avatar
L78_Nova L78_Nova is offline
Originally Posted by Keith Seymore View Post
Do you all know if these little posts are available as a repair?
My Chevelle is missing a couple, apparently from the factory.
K
Au-Ve-Co trim stud repair screw
Most body shop supply stores carry Au-Ve-Co
70 Chevelle SS-454 LS-5 M-22
Keith Seymore (10-14-2022)
  #183
Old 10-14-2022, 05:24 PM
Keith Seymore's Avatar
Originally Posted by L78_Nova View Post
Clear Coat photos
Wow! Looks great! Pretty color.
Did you think this day would ever get here?
K
'63 LeMans Convertible
'63 Grand Prix
Old 10-14-2022, 05:52 PM
L78_Nova's Avatar
K
Ya, it's a looong road. Big project for a back yarder like myself but I normally don't put deadlines on so I just enjoy my pace (and wait on parts).
That said I just entered it for the local March 2023 car show so now it's hammer time !! (It is currently a roller again, will catch up on the posts).
Then MCACN 2023 ?!?
Gary
Old 10-14-2022, 06:27 PM
Looks fantastic. Your dedication to this project is amazing!
Bill Pritchard
  #186
Old 10-15-2022, 02:58 AM
wvhylander wvhylander is offline
These are what I used. I didn't have NOS quarter panels installed so I could drill holes in them for screws. Some folks will use the screws and seal them with urethane. Didn't like the idea of possible water intrusion around the screws.
The Following User Says Thank You to wvhylander For This Useful Post:
olredalert (10-15-2022)
  #187
Old 11-20-2022, 05:43 AM
Darth Darth is offline
Then MCACN 2023 ?!?
Gary
Do you have an update on your project Gary?
Old 11-21-2022, 01:58 PM
L78_Nova's Avatar
Been workin HARD... I'll try to get some pics up this week.
G
Old 11-22-2022, 07:40 PM
L78_Nova's Avatar
Well once you've spent hundreds (cough cough 1000's ?) of hours getting the body as straight as you can and having it painted what any insane person would do is start sanding it for polishing
Most of us know of the typical flaws of dust, drips, runs, orange peel can be reduced or eliminated with polishing. This clear was applied in two fairly heavy coats, scuffed and allowed to "gas off" for several days then hit with another two heavy coats. With the specific purpose to have good thickness for sanding and polishing. The part I didn't know is, this particular production clear (with surface additive) is not very friendly to sand or polish.
The sail panels had about the worst orange peel, the light reflection and angle here makes it appear exaggerated and very obvious. (I had already started sanding the side of the quarter)
Similar surface finish on the trunk appears much better at this angle of view
And the lower rocker area... the reflection in the red box area shows the surface imperfections which were pretty consistent on the whole rocker but show up more in the right reflection.
I was STRONGLY advised by the paint shop to not go more aggressive than 1000 grit to start (we'll get back to that later). For most areas I use this aluminum block wrapped with wet/dry paper and use a spray bottle with a couple drops of dish detergent for lubrication and to clear the sanding residue.
This is the same rocker area after a first pass with 1000. You have to make many rounds sanding, wiping and drying off to watch your progess. The high spots show up as dull (sanded) and the low spots remain shiny. You have to be VERY cautious around edges. You can see on the door... I have stayed away from the body line with the coarse paper. The paper will cut aggressively across corners and edges so it is easy to cut through the clear.. then it would require repainting. As soon as you cut through the clear the base color will also require repainting. Experience, experience, experience... I have watched many and learned (and burned though before). You have to be careful and patient with the sanding... it is easy to sand out a low spot if you cheat the paper and dig in an edge of the block. You need to be very consistent with holding the block flat against the surface and checking progress often. You can't see anything when it is all wet. And just like with bodywork the straighter and flatter you get it, the longer it takes to remove material.
The top of the drivers door had a couple of heavy runs which I first scraped down with the flat (90 degrees to surface) edge of a razor blade.
Then further sanded out.
Picture of the quarter progress.
The Following 4 Users Say Thank You to L78_Nova For This Useful Post:
big gear head (11-23-2022), RPOLS3 (11-23-2022), SPEEDYB (02-27-2023), Xplantdad (11-22-2022)
  #190
Old 11-22-2022, 09:14 PM
L78_Nova's Avatar
The desired result of the sanding is to achieve a perfectly flat surface in preparation for polishing.
Rocker
Left Quarter
Started into the sail panel
Trunk
Most of one half
Here's where things get interesting... After sanding every square inch with 1000 grit, You have to follow up with ;
1200
1500
2000
2500
The first grit is the most time consuming because you have to remove the surface defects and the following grits only have to remove the previous grit scratch however....
You can understand where the hours start to pile up.
After 2500 I also quickly orbital wet sand with 3000, 5000 and 8000 to cut down on polishing time (arguably ? as most polishing time is spent removing stray coarse scratches which the orbital grits would not cut out)
The Following 8 Users Say Thank You to L78_Nova For This Useful Post:
big gear head (11-23-2022), BLACKLS5 (11-23-2022), chevyman0429 (11-22-2022), Dave Rifkin (11-23-2022), Donnie (11-22-2022), RPOLS3 (11-23-2022), scuncio (11-22-2022), Xplantdad (11-22-2022)
