Old 10-19-2022, 07:24 PM
Donnie's Avatar
Donnie Donnie is offline
post a pic of the converter both sides.
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 10-20-2022, 11:31 AM
TomN TomN is offline
Thanks Donnie. Converter is in the car now - so when I get the car back home from the mechanic's house, who is doing the work for me, I'll see what pictures I can come up with
I believe from what I remember the trans is from a 1970 or 71 Impala (from the trans code on the side of the case). Also the shifter lever is for a column shifter - we are swapping that out this week for one for a floor shifter.
Old 10-20-2022, 12:44 PM
If the converter is still from the Impala, it's not going to work with the L78 cam, as you are aware of. You'll need a converter to match the application, with a higher "stall" speed, either a rebuilt original or an aftermarket tuned to the cam.
Old 10-20-2022, 01:55 PM
Thanks Mitch. Yes you're right. I need a converter that will let the engine idle higher in gear - but I don't want a real high stall converter either. I enjoy the Pure Stock Muscle Car Drags and would need a converter that wouldn't blow-off F-70-14 tires.
But if I understand correctly - the stock converter did let the engine idle at about 750 rpm's and had a 2,200? rpm stall
Old 10-20-2022, 02:20 PM
Yes,as that's what my L-78 TH-400 transmission lets it idle at.
Old 10-20-2022, 10:43 PM
WILMASBOYL78's Avatar
WILMASBOYL78 WILMASBOYL78 is online now
Post L78 with TH400...
The idle aspect is only part of the transmission issue...the hi-perf trannys used behind the L78 were special built units. They had stronger internals, the 6 lug high stall converter, a hi shift point governor and other unique features. There was an old thread about this, not sure if the info is still accessible.
https://www.yenko.net/forum/showthre...ighlight=trans
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 10-21-2022, 01:49 PM
Thanks for the info on the transmission. Right now the trans seems fine, I'll know more soon as the car is getting close to being drivable
Old 10-21-2022, 08:49 PM
And the new Disc Brake Hold Off Valve leaks ..... so I've ordered another one
The transmission in my car has a "CR" code with a black tag - no picture, but the torque converter only has 3 bolts.
Old 10-22-2022, 01:10 AM
Post Th-400..
For 70-71 the 'R code' TH-400 would be a 454 application from a Chevelle...
The 3 lug converter indicates a low-horse option...
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 10-22-2022, 04:04 PM
That's what I was thinking - but no way to know IF the trans has been up-graded without taking it apart, and I don't plan to just do that with the trans working good.
But the converter has to be changed
