Old 06-06-2022, 12:58 AM
Looks good Matt!! Two things, your upper radiator hose is on backwards and your ground battery cable should go to the thermostat where the alternator bracket bolts too. All it needs next, is a complete smog system and you will be done. Nice job...
cruiserofland (06-08-2022)
  #122
Old 06-06-2022, 11:15 AM
COPO COPO is offline
Terrific photos and nice details.
The Following User Says Thank You to COPO For This Useful Post:
  #123
Old 06-06-2022, 11:22 AM
dykstra's Avatar
dykstra dykstra is offline
Turned out great!!
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
  #124
Old 06-08-2022, 12:38 AM
cruiserofland's Avatar
cruiserofland cruiserofland is offline
Thanks, all! Good point, Mark, on the upper radiator hose. I must admit I didn't notice that!
On the ground cable, I've got a battery with the positive terminal inboard and so away from the fender, which I like from a safety perspective, but it means I need to source a factory-looking but longer ground cable to reach that factory ground point on the thermostat.
~Matt
'69 Z/28 RS
'77 F100
'83 FJ60
'10 WC50
‘24 J250
Old 06-08-2022, 09:43 PM
Matt,
If you run your Neg. cable in front of your washer jug instead of the backside, it looks long enough to reach the thermostat housing stud. Give it a try!!
Old 06-13-2022, 05:30 AM
Doesn’t quite reach, but it turns out that Lectric Limited carries extra-long negative cables for just such an occasion so order placed
Today I finally installed an NOS temp sender that I’ve had on a shelf for a while, correct for the console gauges, and crimped a ring terminal onto the existing wire to replace the clip-on connector from the old stud-style sender. Swapped the upper radiator hose around while I had the water out - slowly knocking down projects. Gotta clean those plug heat shields!
~Matt
'69 Z/28 RS
'77 F100
'83 FJ60
'10 WC50
‘24 J250
The Following 7 Users Say Thank You to cruiserofland For This Useful Post:
Dave Rifkin (06-13-2022), dykstra (06-14-2022), markinnaples (06-13-2022), olredalert (06-13-2022), RPOLS3 (06-13-2022), Woodrock (06-14-2022), x77-69z28 (04-25-2023)
  #127
Old 10-15-2022, 12:22 AM
Took a few photos with the new iPhone today… can’t imagine a more fun way to commute on a beautiful fall Friday
~Matt
'69 Z/28 RS
'77 F100
'83 FJ60
'10 WC50
‘24 J250
The Following 21 Users Say Thank You to cruiserofland For This Useful Post:
169indy (10-16-2022), 69M22Z (10-15-2022), big gear head (10-15-2022), Charley Lillard (10-18-2022), COPO (10-15-2022), Dave Rifkin (10-15-2022), dykstra (10-16-2022), Jims69z28 (10-15-2022), L16pilot (10-15-2022), L_e_e (10-15-2022), markinnaples (10-15-2022), napa68 (10-15-2022), Oldss (12-01-2022), olredalert (10-15-2022), PeteLeathersac (10-15-2022), RPOLS3 (11-30-2022), SS4Real (10-15-2022), Steve Shauger (06-11-2023), Tenney (10-15-2022), X66 714 (10-15-2022), x77-69z28 (04-25-2023)
  #128
Old 10-15-2022, 07:48 PM
Man, that thing is beautiful, congrats.
John 10:30
cruiserofland (10-16-2022)
  #129
Old 11-28-2022, 02:24 AM
I mounted our CamBox “helmet” camera to a hat to capture a bit of today’s beautiful Sunday drive. Totally addicted to that chambered exhaust. Happy fall y’all.
~Matt
'69 Z/28 RS
'77 F100
'83 FJ60
'10 WC50
‘24 J250
The Following 8 Users Say Thank You to cruiserofland For This Useful Post:
169indy (11-28-2022), 427 (11-28-2022), 69M22Z (11-28-2022), COPO (11-28-2022), dykstra (11-28-2022), napa68 (11-29-2022), olredalert (04-15-2023), x77-69z28 (04-25-2023)
  #130
Old 11-28-2022, 10:21 AM
69Z11Pacer396 69Z11Pacer396 is online now
Beautiful car! Congrats! Have Gardner chambered exhaust on order for my big block pace car, can't wait to hear it..
The Following User Says Thank You to 69Z11Pacer396 For This Useful Post:
cruiserofland (11-29-2022)
