Old 01-01-2023, 08:45 PM
tom406 tom406 is offline
Default Correct style trim rings for 1967 SS396 Chevelle with disc brakes
I have a friend who just picked up a nice ‘67 SS396 with the wrong wheels on it. Factory disc brake car so it needs some DG stamped 14x6 Rallys (anyone have a set?), but I see conflicting suggestions over what are the right style of trim rings, mostly in terms of the detail around the valve stem opening. If one of you here who knows ‘67’s well could chime in with descriptions (and hopefully photos) of what you think are the right ones, I’d appreciate it. Its an 03D Kansas car, btw. Thanks!
Attachments - The Supercar Registry IMG_7117.jpeg DSC04095.jpg DSC04094.jpg CAE312D4-8960-4F2C-8ABD-3F2D6353B0F1.jpg
Old 01-01-2023, 09:16 PM
Copo_Cartel's Avatar
Copo_Cartel Copo_Cartel is online now
Yenko Premier Member
Call Rick Miller in Utah. 435-668-7062
He is the go to guy and this is his business.
The Following 2 Users Say Thank You to Copo_Cartel For This Useful Post:
69M22Z (01-01-2023), tom406 (01-01-2023)
Old 01-01-2023, 09:31 PM
Tom - I replied to your PM. Jeff
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
The Following User Says Thank You to jeffschevelle For This Useful Post:
tom406 (01-01-2023)
Old 01-01-2023, 10:38 PM
69M22Z 69M22Z is online now
Rick Miller is definitely the guy.
The Following User Says Thank You to 69M22Z For This Useful Post:
tom406 (01-01-2023)
Old 01-01-2023, 11:45 PM
70 copo 70 copo is offline
Really good evidence for U shape during the period in question on DG's for Camaro.
Old 01-02-2023, 01:57 AM
This 375hp car featured in the July ‘67 Motor Trend has factory disc brakes & rally wheels. Those look like the shallower U shaped cutouts to my eye, but its hard to tell for sure. Looks like some gap between the edge of the ring and the inside face of the wheel.
Old 01-02-2023, 03:02 AM
169indy's Avatar
169indy 169indy is offline
Default "IF" 14x6 1967 and 1968 are same?
I have run a hodgepodge of rings. Finally Pulled what I believe are the correct 14x6 versions in my attic.
If 67/68 are similar ?? Not sure.
I have ran a set of 14x7 (1969) four clip rings on the red 68 for years and am transitioning to the slotted shallower rings vs- 1969 ellipse deeper rings.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 01-02-2023, 03:08 AM
67since67's Avatar
'67 DG wheels on a Chevelle used the 2 1/2" oval hole 4 clip ring whereas Camaro used a slotted ring.
The Following 4 Users Say Thank You to 67since67 For This Useful Post:
69M22Z (01-02-2023), olredalert (01-02-2023), RPOLS3 (01-03-2023), tom406 (01-02-2023)
Old 01-02-2023, 03:21 AM
DEUCE DEUCE is offline
Default DG Rally Wheels
I have a set of 5 DG wheels dated 12/66, if your interested.
Mike
The Following 2 Users Say Thank You to DEUCE For This Useful Post:
enio45 (01-02-2023), tom406 (01-02-2023)
Old 01-02-2023, 09:17 PM
Thanks for replies, PM sent DEUCE.
