Old 02-22-2023, 09:51 PM
dannystarr dannystarr is offline
Default Z/28
Yes hoping it helps with dead-stop-take-off. That's what I was told it would do. ...
Right Firewall area after cleaning. No 2nd Hidden VIN in the area that I could find. I will look again around the whole area. D
The Following User Says Thank You to dannystarr For This Useful Post:
markinnaples (02-23-2023)
  #72
Old 02-22-2023, 09:57 PM
Default Z/28
Body Part Stamp. 2nd Week of June? ... D
The Following 2 Users Say Thank You to dannystarr For This Useful Post:
big gear head (02-23-2023), dykstra (02-22-2023)
  #73
Old 02-22-2023, 11:18 PM
black69 black69 is offline
I have to ask, is it typical the door panel and dash shade of blue does not ideally match the seat color, and carpet? door panels look mint and back seat looks mint.
Old 02-22-2023, 11:39 PM
I never see anything match. Door panels, Seats, Door handle bases and pads, kick panels, Dash, head liner etc. Not in 717 medium blue anyway. I think because they are all different material make-up and texture.
Some are smoothish plastic, some are rough plastic, then vinyl etc. Then you add years of aging and it's over doneso. The only time it all matches very close is when you buy aftermarket.
Our VINS are about 9,000 apart? D
Old 02-23-2023, 04:38 PM
Thanks Danny, I kinda figured. This is why I like original cars.
Our vins are more in the range of 8300 or so apart. Your guess was dang good.
The selling dealer of my car (Nickey Chevrolet) told the owner that he is on the edge of getting his order filled/processed and would he be ok with a 69. So I guess this was bumping up against the end.
Old 02-23-2023, 04:40 PM
Thanks Danny, I kinda figured. This is why I like original cars (like yours).
The selling dealer of my car (Nickey Chevrolet) told the owner that he is on the edge of getting his order filled/processed and would he be ok with a 69 if it does not make it. So I guess this was bumping up against the end, yours especially.
Old 02-25-2023, 01:56 AM
Hey Danny, had a question based on your info you posted that only 2147 cars built in July.
If my car is a 7C and yours is a 7E, why is my VIN 8300 or so before yours????
Wont be the first time I get something wrong. If what you are saying is true, my car should have been a June car? Confused. My block is cast F 17 8 by the way, and again assembled 10 days before yours (as said earlier).
Old 02-25-2023, 04:45 PM
I can't answer that, as I don't have the knowledge. There is some anomalies happening during this time. Stock being cleared out and used up for the new model year. My VIN falls in June Build time period. About 1,436 from the end of June production. Cowl tag is 07E. WAY late 5th week of July. I would have thought the VIN would have been much later. That's alot of time. Maybe there was a stock issue for the order of my car? And that held things up? See Asterisk below with info from the CRG website. Explains it pretty well with the info that is available at this time.
All I know is I am glad the Engine, Trans, 1st Hidden VIN, Driver Side VIN plate, POP and Title all match.
The list below is Chevrolet's documentation of the end-of-month VIN for the GM assembly plants. * Due to several limitations the VINs in this list will not necessarily correlate exactly with either a specific calendar day or the build week on the cowl tag. The data for some months (especially May and June 68 at Norwood) deviate significantly from actual build dates, while other months correlate well.* We are unsure of the source of these deviations, but uncertainties include:
It isn't known what day of the month was used for logging the monthly production, or if the same system was used for all years.
Vehicles were NOT assembled in the exact order of VIN. For any given VIN selected as the nominal "last" for that month, it is likely that slightly lower or higher VINs might either still be in process, or might have already been assembled.
The build date on the cowl tag is when the body was started. It was attached 3-4 days before final assembly of the car was completed and build week dates did not always align with calendar weeks.
Despite these limitations, the list remains a useful guide for approximate confirmation of date as to when a given VIN was built.
1968 Model
Sep-67 8L304745 4745 8N319989 19989
Oct-67 8L309652 4907 8N337720 17731
Nov-67 8L315860 6208 8N352898 15178
Dec-67 8L321968 6108 8N368090 15192
Jan-68 8L328091 6123 8N381420 13330
Feb-68 8L331484 3393 8N392427 11007
Mar-68 8L335251 3767 8N407303 14876
Apr-68 8L338564 3313 8N425530 18227
May-68 8L342085 3521 *8N465482 39952
Jun-68 8L345432 3347 *8N482588 17106
Jul-68 8L349164 3732 8N484735 2147
Old 02-25-2023, 04:48 PM
Default Z/28
Left and Right Brake assembly. Both drum adjuster windows un-punched.
The Following 3 Users Say Thank You to dannystarr For This Useful Post:
69M22Z (02-26-2023), big gear head (02-26-2023), Dave Rifkin (02-25-2023)
  #80
Old 02-25-2023, 04:49 PM
Default Z/28
Right
