Old 03-29-2023, 11:57 PM
Hawkeye's Avatar
Hawkeye Hawkeye is online now
Default Smog tube’s application
All,
I would like to figure out what application the photo’d small block smog tubes fit. Any and all help is much appreciated.
Thanks, Marty
Attachments - The Supercar Registry 9E2EC55D-3AF5-49D6-A31C-54FBF3564D9D.jpg
Old 03-30-2023, 12:23 PM
Bottom tube looks like Camaro 69-72 small block applications. Top tube not sure.
Owned since 1978 - First Car
The Following User Says Thank You to BCreekDave For This Useful Post:
Hawkeye (03-30-2023)
Old 03-30-2023, 06:45 PM
Those are for 78-81 Z28's without A/C.
Old 03-30-2023, 08:31 PM
Hawkeye's Avatar
But they came attached to a 69 dated pump with original hoses and clamps. Hockey stick tube definitely applies to 69 Camaro. Just need to figure out exact application for top tube. Thanks for the response.
The Following User Says Thank You to Hawkeye For This Useful Post:
carnut4life (03-30-2023)
Old 03-30-2023, 09:54 PM
Was a Z28 the only small block to have a smog pump in 1969 or did California cars have them too?
Old 03-30-2023, 11:00 PM
SS with manual trans also got smog pumps.
I removed a smog set up from a 69 El Camino with 307 three on the tree. I do not know if ALL the manual trans small blocks got it. L48 small block definitely did.
carnut4life (03-31-2023), Hawkeye (03-31-2023)
Old 03-30-2023, 11:14 PM
X66 714's Avatar
X66 714 X66 714 is offline
Lots of good information here...Joe
http://www.camaros.org/emissions.shtml
The Following 2 Users Say Thank You to X66 714 For This Useful Post:
