Old 03-29-2023, 11:09 PM
427.060 427.060 is offline
Default Brake Caliper Rebuild
Who rebuilds/restores brake calipers? I need the 4 piston calipers for my Beaumont rebuilt. I'm having a hard time just finding rebuild kits for the 4 piston ones.
Thank you, James
1968 Beaumont SD396
Attachments - The Supercar Registry FA7385AB-9984-45C8-BF7A-1935349726D0.jpg F6C163FD-95F3-4AA3-982B-91220DD53FA1.jpg D7DB5AE7-089D-4CD4-9EFB-16A1951EF26D.jpg 2DEEA45C-FE7D-4E3A-9B49-6C5EF23E22CE.jpg
Old 03-30-2023, 02:39 AM
69 Post Sedan's Avatar
I’ve sent mine to Muskegon Brake in Michigan. They do wonderful work.
https://muskegonbrake.com/pages/rebuilding-services
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 03-30-2023, 03:44 AM
67since67's Avatar
Muskegon Brake sublets 4 piston caliper sleeve/rebuild to Lonestar Caliper. Lonestar says they are wholesale only.
I have had two pairs of '67 Chevelle 4 piston calipers done by them, both had leaks on the driver's side. The first was resolved with the first return. the second was returned three times, each time the leak was a different place.
The routine was, I call Muskegon, send them the leaker, a couple weeks later Lonestar ships directly back to me.
A problem with these Chevelle 4 piston calipers is lip seals, no O-ring seals are available (2 1/16" IIRC) whereas Corvettes use O-ring seals. Do not use DOT 5 fluid!
Just my experience, I have three NOS HURST/AIRHEART kits is you are interested. - Bill W
Copo_Cartel (03-30-2023)
Old 03-30-2023, 10:30 AM
That’s good info Bill.
The first time I used them was over 20 years ago for my 1968 Nova I had, which had 4 piston calipers. I didn’t have any issues and I owned it for approximately 8 years after having them rebuilt.
The second time was a few years ago for my Chevelle. They are single calipers…..with no issues.
Kurt
Old 03-30-2023, 11:00 AM
COPO COPO is offline
At least in the past, White Post Restorations was the go to place in the eastern part of the country for this type of work. I don't have any recent experience with them, so cannot comment on their present reputation.
https://whitepost.com/brake-sleeving...ding-services/
The Following User Says Thank You to COPO For This Useful Post:
69M22Z (03-30-2023)
Old 03-30-2023, 01:03 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
I was able to send mine out to the local NAPA store - I believe they use Cardone. They tagged them accordingly and returned my originals rebuilt and ready for paint/detailing.
Jake Dykstra
Dykstra Motorsports
69M22Z (03-30-2023)
Old 03-30-2023, 03:34 PM
scuncio scuncio is offline
FWIW - I had my Z/28 calipers resleeved maybe 15 years ago, by Vette Brakes, and have used DOT5 in that car ever since with no problems.
Old 03-30-2023, 04:19 PM
Thanks for the responses. The NAPA here doesn't offer a rebuild service for these. I checked with White Post and Goldline Brakes. Also called Muskegon but no one answered the phone. Has anyone heard of or used Phoenix Caliper out of Chicago? Prices from each of these companies varied a lot. Goldline was $1400 for a set. White Post was $640. Phoenix was almost too cheap at $290 with a 2 day turnaround.
Since no one answered at Muskegon I called Lonestar hoping that they weren't wholesale only. They are not. They are $480 for the set with a one week turnaround. I think I will use Lonestar.
I had checked with all of the local parts stores and Chevelle parts suppliers. None of them can get rebuild kits for these 4 piston calipers.
1968 Beaumont SD396
Old 03-30-2023, 05:36 PM
67since67's Avatar
Memory jogged Tony, Vette Brakes did my Corvette calipers in 1982. Zero issues in 40 years.
Old 03-30-2023, 05:43 PM
67since67's Avatar
Chemistry is not my strong suit, I have been told by Muskegon that the old formula DOT 5 has not been available for several years and that current DOT 5 is not compatible with the brake parts in our old cars.
Lonestar, and I believe White Post and Karps warranty is voided with DOT 5.
If this is incorrect, please set me straight! - Bill W
