Old 09-05-2023, 11:11 AM
VetteSpaz VetteSpaz is offline
Default Air Cleaner Lid Upper Side Re-Chroming?
Hello Guys,
I've been researching if it's possible to have the upper side only re-chromed on air cleaner lids? I recently purchased an original '66 Corvette 427 survivor lid that has a very nice underside AC instruction silk screen that I want to protect.
Does anyone have contact info of platers that will do this job? Any testimonials of work done? I've been told that this process is possible.
Here's the subject lid. Mike
Attachments - The Supercar Registry Mike's '66 427 Lid (7a) (30)a.jpg Mike's '66 427 Lid (3a) (30)a.jpg Mike's '66 427 Lid (1a) (30)a.jpg Mike's '66 427 Lid (10a) (30)a.jpg
Old 09-05-2023, 11:52 AM
scuncio scuncio is offline
I did have that done on my '70 Chevelle's air cleaner lid, and was able to preserve the silkscreening on the lower surface. This was 30 years ago...I believe Badger Industries in Milwaukee.
The Following 5 Users Say Thank You to scuncio For This Useful Post:
Blown32 (09-05-2023), dykstra (09-05-2023), L72copocamaro (09-07-2023), RPOLS3 (09-05-2023), VetteSpaz (09-06-2023)
Old 09-06-2023, 05:29 AM
L72copocamaro L72copocamaro is offline
Good to know!
Old 09-06-2023, 06:50 AM
If they do it the same way the factory did its Flash Chrome.
Flash chrome is similar to hard chrome, in that it is plated in a bath of chromic acid, but the electroplating process is completed rather quickly as the desired thickness is much smaller. Flash chrome plating adds a very thin layer of chromium generally consisting of deposits with a thickness of 0.0002 to 0.0005.
Old 09-06-2023, 10:17 AM
MosportGreen66's Avatar
Personally, I would not. Leave it as is and find a nice one. Plenty exist. No vendor will get it close to oem flash chrome. Been there done that numerous times.
Old 09-06-2023, 10:27 AM
69L78's Avatar
69L78 69L78 is offline
Tri-City Plating in TN does flash chrome, You need to tell them you want "Production" chrome or NCRS Chrome & not to polish the pieces. They go nickel, then they will lightly scuff them nickel again & then chrome....No Copper. For reference, the last time I checked, they quoted me $250 ea. to do BB valve covers.
Tri-City Plating
218 E Mill St
Elizabethtown TN 36743
(423) 542-6532
The Following 3 Users Say Thank You to 69L78 For This Useful Post:
big gear head (09-06-2023), olredalert (09-06-2023), VetteSpaz (09-06-2023)
Old 09-06-2023, 07:35 PM
enio45 enio45 is offline
how do they do one side only???????
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 09-06-2023, 08:03 PM
BCreekDave BCreekDave is online now
Knowing what little I do about industrial plating, there are coatings (think grease-like substances) that can be applied to mask the area where you do not want the plating to occur. These are then washed off later.
Owned since 1978 - First Car
The Following 2 Users Say Thank You to BCreekDave For This Useful Post:
olredalert (09-07-2023), VetteSpaz (09-06-2023)
Old 09-06-2023, 09:23 PM
Thank you guys for all of your inputs so far. I'm making note of all of them. So far I've got one solid lead here:
-Badger Industries in Milwaukee
Please keep names coming of plating companies that have done this type of re-chroming for you.
Mike
Old 09-06-2023, 09:33 PM
Try Courtesy Metal Polishing in Villa Park Il.https://www.courtesymetalpolishing.com/
I was a regular customer,from 1985 up until around 2015.They were epic in everything I gave them.No idea who is in charge there now,or their quality of work.
The plating world has drastically changed since.
Good luck in your search.
