Old 10-17-2023, 08:11 PM
Zman1969 Zman1969 is offline
Default BBC head gaskets for alum heads
anyone have recommendations for BBC head gaskets for Aluminum heads I have a set of Victor Reinz composite/Graphite or use Fel-Pro blue's? or what were OE with Alum heads?
this is for a 396 if bore size matters (most I see are listed at 4.370 bore)- I'd appreciate your suggestions.
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 10-17-2023, 10:46 PM
FelPro made a blue gasket that had a copper fire ring for aluminum heads. I used them for many years. I now use Cometic gaskets. I don't know if FelPro still makes the other gasket.
Old 10-18-2023, 01:41 PM
Thanks Freddie I called Fel-Pro and thy suggested the PN# 1027 with the copper for the Aluminum heads
90 Formula 350
The Following User Says Thank You to Zman1969 For This Useful Post:
big gear head (10-18-2023)
Old 10-19-2023, 10:23 AM
Copo_Cartel's Avatar
Yenko Premier Member
I have original GM NOS BBC Aluminum head gaskets
Old 10-19-2023, 09:49 PM
I use the Fel-Pro 1027 remember to order 2
Old 10-20-2023, 08:37 PM
pictures ? just curious I've never seen any
Check on order 2!
90 Formula 350
