Old 11-28-2023, 12:39 AM
ALLZS ALLZS is offline
Default rearend stamping
where the 12 bolt rearends assembled at eaton or by the gm plant
Old 11-28-2023, 11:59 PM
Kurt S Kurt S is offline
Chevrolet Gear and Axle division. Eaton was just the posi supplier.
Kurt S - CRG
Old 11-29-2023, 12:47 AM
WILMASBOYL78's Avatar
WILMASBOYL78 WILMASBOYL78 is online now
Post 12 Bolt Axle...
The letter code will indicate assembly plant. Those with an 'G' code were Detroit Gear and Axle. E is an Eaton posi...
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 12-07-2023, 12:00 AM
Mike L78 Mike L78 is offline
Default 12 bolt nova vs camaro
How can you tell if a BT 12 bolt is from a nova or camaro ?
Old 12-07-2023, 01:16 PM
Post BT rear...
The casting numbers were the same...and as far as I know, all the mechanical features were the same. Pretty sure they are interchangeable.
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
The Following User Says Thank You to WILMASBOYL78 For This Useful Post:
Mike L78 (12-07-2023)
Old 12-07-2023, 06:19 PM
My understanding as well, both 67-69 Camaro and 68-72 Nova are interchangeable measurement wise. I am not sure on the codes. Bill
The Following User Says Thank You to Big Block Bill For This Useful Post:
Old 12-07-2023, 07:52 PM
Default Rear End Codes...
If you look at Colvin's book, there were more choices with the Camaro. The BT rear was a common item for these cars....pretty much all the codes were the same.
-wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Big Block Bill (12-07-2023)
Old 12-07-2023, 09:42 PM
Lynn Lynn is online now
There would be no way to tell which car it came in originally without history.
