Old 11-29-2023, 05:12 PM
Rumbleguts396 Rumbleguts396 is offline
Default Day 2 ignition box ID
Hello all, I’m looking for some help trying to ID the Day 2 after market ignition box that was previously installed on the firewall of my 1969 Big Block Camaro. I’ve owned the car about 15 years and the original drivetrain is all missing. So I restored it into a Day 2 street car. The previous owner told me it was a street racer turned 1/4 mile track car. But never cut up. I’d like to reinstall the same ignition box that was previously installed prior to my ownership. The only thing I have to go on is 2 screw holes in the firewall directly above the heater core box. The 2 holes are 3 1/4 inches apart. The typical boxes that I’m aware of that used 2 mounting holes are Mallory (see 2 photos) and Accel square style boxes. However they don’t come even close to fitting directly above the heater box and hood when closed (unless the heater box was removed back in the day). So this leaves me with the long narrow MSD etc style ignition boxes, however those are 4 hole style boxes. Anyone have any suggestions or clues of manufacturers that used 2 mounting holes spaced 3 1/4 inches apart? Much appreciated Rob
Found my answer!!!
1969 Camaro SS 396 X66 Lemans Blue
1969 Corvette 427/390 Lemans Blue
The Following 6 Users Say Thank You to Rumbleguts396 For This Useful Post:
big gear head (12-04-2023), Carleen (12-06-2023), dykstra (11-30-2023), Hawkeye (11-30-2023), olredalert (11-30-2023), Zman1969 (12-08-2023)
Attachments - The Supercar Registry IMG_8230.jpg IMG_8229.jpg IMG_8228.jpg IMG_7923.jpg
Old 11-30-2023, 11:02 AM
Found my answer, The Mallory does barely fit, but fits. Rob
Old 11-30-2023, 01:41 PM
Hawkeye's Avatar
Hawkeye Hawkeye is offline
Default Great detective work!!
Glad you found your answer. The Mallory coil will look good on the firewall. It would be very helpful if you posted photos of your Camaro.
The Following User Says Thank You to Hawkeye For This Useful Post:
Rumbleguts396 (11-30-2023)
Old 11-30-2023, 08:50 PM
Now you need the electronic ignition, shutter wheel, distributor conversion to go with it...
Old 12-03-2023, 05:15 PM
NHBandit NHBandit is offline
Any holes under the dash that might correspond to one of these ? My 36 Chevy gasser that raced in the 60s came with one.
The Following User Says Thank You to NHBandit For This Useful Post:
Rumbleguts396 (12-03-2023)
Old 12-03-2023, 05:48 PM
Hmmm, I never looked. I'll take a peak. Rev Pol, Hope so !!! Rob
Old 12-04-2023, 11:13 AM
dykstra's Avatar
dykstra dykstra is online now
Found my answer!!!
What a fantastical bad azz stance!!!!
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
Rumbleguts396 (12-04-2023)
