Old 12-11-2023, 04:24 AM
BJCHEV396's Avatar
Business must be real good at Heartbeat!
Old 12-11-2023, 12:13 PM
bergy's Avatar
bergy bergy is offline
Angles are different, but the top looks pretty much the same as the regular cross ram top. I'm sure that the bottom is different, but can't imagine that it would be too difficult to produce a pattern with today's technology. Heck - someone modified the bottom mold to fit the hemi heads 50+ years ago.
67 Nova Boy (12-18-2023)
  #23
Old 12-11-2023, 12:21 PM
HuggerSS HuggerSS is offline
The lower intake does not have a part number. The top plate has a part number for the lower and upper intake
The Following User Says Thank You to HuggerSS For This Useful Post:
olredalert (12-11-2023)
  #24
Old 12-11-2023, 04:53 PM
Is it possible there's an extra top so Smokey could use different carbs? Say one setup with 600s and another with 780s? It would make it easier to change than to remove and replace the carbs. Heartbeat may be looking for something that doesn't exist.
Old 12-11-2023, 11:41 PM
Have to wonder why.
The only person known to have worked on the project outside of Chevrolet was Smokey Yunick. In three different articles over the years, he stated the Hemi 302 topped out at around 450 hp. The intake port design compromised exhaust flow.
The small-block hemi head was never released for production or used in competition. It's likely all the parts in existence came from Smokey Yunick's auction.
Over the years I have seen a few Z/28 built with the Hemi 302, one in The Shed collection. Not like he would be the first.
As far as I was told, Bob bought both of the running test cars at the auction. 1 1968 and 1 1969, both dressed as Z/28's. Last I was up there, they were both there, but that's been several years now. The 3rd engine was on a stand at the auction and Bob told me Vic Edelbrock bought that one.
The Following 11 Users Say Thank You to Too Many Projects For This Useful Post:
3X24SPD (12-12-2023), 67 Nova Boy (12-18-2023), dykstra (12-14-2023), iluv69s (12-13-2023), Lee Stewart (12-12-2023), McCune (12-12-2023), napa68 (12-12-2023), Oldss (12-12-2023), olredalert (12-12-2023), PeteLeathersac (12-13-2023), YenkoYS-199Stinger (12-13-2023)
  #26
Old 12-13-2023, 05:41 AM
iluv69s iluv69s is offline
Originally Posted by Charley Lillard View Post
The valve layout is different so what about a cam ?
Yes, cam is reverse lobe.. totally different. Fortunately I got a correct cam with the heads when I bought them.( I recieved the magnesium valve covers and the original rubber valve cover gaskets also)
Old 12-13-2023, 05:43 AM
Hemi top is interchangeable with all X-rams. Only difference I saw ( besides two part numbers) is the mounting flange for the carbs was larger and most likely stronger. Other than that they seem identical.
Old 12-13-2023, 05:55 AM
Tops are identical as far as the fit and function. If they modified a ‘production’ xram, they only used the top 1/2”.
The differences are drastic other than the top 1/2” where the top plate mounts. The port layout is very similar to a Boss 302. ( I bought an original intake to compare ports ) The rad hose mount comes out the front and not on top. Drastically different.
I asked Jim if I could 3-D scan the intake on the silver car when he owned it. I considered trading some ZL-1 parts for the motor out of that car when Jim offered it to me. But we did not end up making a deal and he ended up buying my parts from me.
There was also an auction in Phila years ago that had a hemi head stup along with an original ZL-1 block if I recall. I was out of the country or I probably would have bought it.
The Following 3 Users Say Thank You to iluv69s For This Useful Post:
dykstra (12-14-2023), olredalert (12-13-2023), PeteLeathersac (12-17-2023)
  #29
Old 12-13-2023, 12:05 PM
bergy's Avatar
I went to that auction in Philadelphia. Bought some NOS parts & bid on the ZL1 block (which was badly damaged). Wish I would have known the significance of the hemi head setup:-(
  #30
Old 12-17-2023, 02:15 AM
Billohio Billohio is offline
I remember seeing the silver z at Floyd Garretts museum and that had to be a long time ago. Maybe 20 years ago anyway. I might still have a picture of it
Bill
