Old 12-30-2023, 11:51 PM
CamarosRus CamarosRus is online now
Thanks Ron and Dave,
Dave, Have you read that NORWOOD is sold out of his last batch of Steel Spring Clips
Ron, I'm still wanting info on the plastic pieces , between the leaves ???
Thanks
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 12-31-2023, 12:05 AM
BCreekDave BCreekDave is online now
Chuck
The link I inserted takes you to his response to a recent inquiry for straps.
Owned since 1978 - First Car
Old 12-31-2023, 07:32 PM
Does EATON DETROIT Spring still set the Steel Straps with Square Holes ????
Chuck Sharin
[email protected]
Old 01-01-2024, 12:36 AM
Just curious what these fit.
Look nothing like the riveted ones on my 69 Z/28.
Old 01-02-2024, 10:30 AM
Mr.Nickey Nova Mr.Nickey Nova is online now
I was wondering the same Lynn. Both of my Novas and Camaro have the riveted type also. I always thought the riveted type were factory installed and the square hole type were replacement leafs.
Old 01-02-2024, 11:41 AM
ronzz572 ronzz572 is offline
Eaton spring use the flat straps on the 2nd gen F body, They are very different from the first gen F body spring. I don't have a picture of the straps but a suspension picture may help.
1970 L78 camaro Cortez silver ralley sport under restoration
Old 01-02-2024, 02:01 PM
Just like everything, there were also two versions of the spring wrap clip. Some had square punched holes and end tabs and others had round punched holes with rounded end tabs. The spring in the top of the picture has the rounded hole. Ron's photo has the square style. Also, you can see the original style of anti-squeak plastic leaf separator with the solid hollow oval and the aftermarket with the split oval that I am pointing to in the photo.
Old 01-02-2024, 02:04 PM
I was wondering if they were for second gen. The initial post did not specify.
Charlie's old 70 Z should provide good indication of at least one style used in 1970.
https://www.yenko.net/forum/showthread.php?t=101980
Old 01-02-2024, 05:38 PM
Dave, I'm guessing that no one reproduces the "correct" black plastic piece (between spring leaves).....I would be surprised if that was a point deduction in LEGENDS Judging ????
Have you located a vendor that sells the slotted (no original) type ??? Eaton Detroit ???
Chuck Sharin
[email protected]
Old 01-02-2024, 07:48 PM
I have a .stl file for 3D printing the non-slotted type is you are interested.
The slotted type come with the Eaton-Detroit springs. Not sure if they sell them separately or not. I have a few if you are interested. I took apart my new springs and used several of the best of my old ones and printed a few new ones. Surprised a bit that points are not deducted.
