Old 02-15-2024, 01:24 PM
mhm1966 mhm1966 is offline
Default Steering Wheel Refinish
Has anyone been able to paint 1969 steering wheels. I thought they were plastic, but when I got off the phone with SEM Products tech line, they said the 1969 steering wheels were made of nylon. They he told me that paint will not stick to nylon. Does anyone have any input on this subject?
Attachments - The Supercar Registry Spare wheel after repair 1.jpg IMG_9374.jpg
Old 02-15-2024, 04:04 PM
jl8z28 jl8z28 is offline
It does i have painted them
The Following 2 Users Say Thank You to jl8z28 For This Useful Post:
cheveslakr (02-25-2024), mhm1966 (02-15-2024)
Old 02-15-2024, 04:36 PM
I scuffed one up real well with coarse scotch-brite pad and shot a base of epoxy primer. No problems with adhesion at all.
Owned since 1978 - First Car
The Following User Says Thank You to BCreekDave For This Useful Post:
Old 02-15-2024, 05:12 PM
I was stumped when the SEM tech told me even with an adhesion promoter the paint will not stick. Are you guys using base coat clear coat or a single stage paint. What paint line are you using.
Old 02-15-2024, 05:20 PM
I used SPI epoxy as the base and a acrylic urethane SS Delfleet Essential color (black, in my case) with SEM World Class clear.
The Following 3 Users Say Thank You to BCreekDave For This Useful Post:
mhm1966 (02-15-2024), olredalert (02-16-2024), x44d80 (02-15-2024)
Old 02-15-2024, 08:51 PM
With the clear, it is glossier than original. i wanted the clear for a bit of protection from UV. A satin clear may get closer to original.
The Following 6 Users Say Thank You to BCreekDave For This Useful Post:
bergy (02-16-2024), dykstra (02-16-2024), L16pilot (02-16-2024), L78_Nova (02-16-2024), mhm1966 (02-16-2024), olredalert (02-16-2024)
Old 02-16-2024, 10:45 PM
Has anyone tried satin clear?
Old 02-18-2024, 12:58 AM
camarojoe's Avatar
They weren’t satin, the plastic was very glossy when new. Not “3 coats of urethane clear” glossy, but definitely not satin.
Joe Barr
The Following 5 Users Say Thank You to camarojoe For This Useful Post:
Big Block Bill (02-25-2024), cheveslakr (02-25-2024), Hawkeye (02-18-2024), mhm1966 (02-25-2024), olredalert (02-18-2024)
Old 02-25-2024, 01:19 AM
DAVE, Curious why you didnt use SPI Universal Clear ?????
Anybody know if a Glazing Putty like UPOL Dolphin Glaze would
work on Minor Scratches or or will the EPOXY Fill and then sand
that.......??? or will Sanding the Epoxy Gum up the paper..........
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 02-25-2024, 02:05 AM
I've done several '69 wheels. If the wheels are really nice and only showing very minor flaws I just sand with 1000-1500, then hand buff. If you're going to repaint and know you're going to cut and buff, then paint a satin or a bit shinier, then cut and buff and your wheel will show the gloss but won't have the depth, which is exactly what the oem finish was. This is my preferred method. Spi epoxy and their SS urethane is the ticket.
