Old 03-22-2024, 04:46 PM
Derek69SS Derek69SS is offline
Originally Posted by Zman1969 View Post
Cool project Derek! so that low compression may make it run like a pig you may want to swap for some small chamber heads or get bigger domed pistons! my 69 is being built day two also I'll be following along on your journey
did you ever find rest of the valve? LOL
I have a 427 sitting here that's supposed to be 12:1 with 840 heads, so swapping heads between the two would make both of them better. The goal for now is just to get the car running and driving on the cheap with stuff I have on hand. After throwing money at another car for years, this one is going to be fun to play with mostly used parts and stuff I have laying around.
We broke the valve on Saturday. The valve was stuck open, so when we set the lash, without realizing it wasn't closed, the rocker was tightened down enough to make it hit the piston. Whoops...
The Following User Says Thank You to Derek69SS For This Useful Post:
dustinm (03-22-2024)
