Old 04-13-2024, 01:33 PM
Wondering where a clean frame could have come from unless a totaled car ? Have you had the replacement frame checked for square and plumb on a frame rack ?
Old 04-13-2024, 06:11 PM
Did the Vette frame get the VIN stamped on it like the Chevelle?
Old 04-13-2024, 09:20 PM
Ralph Spears's Avatar
Ralph Spears Ralph Spears is online now
Yes,The Corvette had the VIN stamped .
Old 04-14-2024, 02:28 AM
I thought the same thing. I don't have a frame rack, and i don't have a perfectly flat surface in my shop.
What I have done is check if for square every which way. All good. Anything that could be measured for square, I measured. I figured if it was in a wreck, SOMETHING would likely be out of square.
Old 04-14-2024, 03:13 AM
Sounds like it is good. I had the advantage of working at a frame shop and took all my frames there to be measured on a rack. Since he sold out 2 years ago and I don't work there anymore, the next car ('70 Chevelle) will need to go somewhere else and cost me money...and I know that one needs work...
Old 04-15-2024, 01:51 AM
Originally Posted by LT1vette View Post
Not an easy task you are getting yourself into. There are shims at each body mount. When you remove the body mount, DON"T lose the shims.
Yup. Eyes wide open. I knew is would be a challenge.
All the shims are simply thick aluminum washers on this car.
All are corroded to some extent, with some being worse, and several are in pieces. When aluminum corrodes, it swells.
Most of them still have remnants of paper tape that I assume helped hold them in place.
The ones that aren't swollen all mic at .385. The rest; who knows.
The Following 3 Users Say Thank You to Lynn For This Useful Post:
dykstra (04-16-2024), markinnaples (03-11-2025), olredalert (04-15-2024)
  #27
Old 04-15-2024, 01:53 AM
Original nodular iron flywheel. Dated Dec. 69, which about right for my Feb 11 built car.
Old 04-15-2024, 01:55 AM
Oops. Forgot flywheel pics.
Old 04-15-2024, 01:57 AM
Original trans tag and stamps.
The first digit on the tag is a 3. Covered up with grease.
  #30
Old 04-15-2024, 02:09 AM
Holley Carb. Apparently, the original was swapped out somewhere along the way.
This one looks pretty grimy, but it ran perfectly. No hesitation; no flat spots.
Has correct metering plates. 6333 & 4519.
As you can see, this one is dated fourth week of May, 1970, so not original to my Feb 11 car.
I was told by a member here that this is actually a very desirable date code. Same carb was used on 1970 Z/28 with manual trans, and on the Yenko Deuce.
I will probably send it off to Eric and have it restored. Will then ask a ridiculous amount of money for it, and hope to parlay that into purchasing a Dec 69 or Jan 70 carb.
