Go Back   The Supercar Registry > General Discussion > AMC
Old 04-15-2024, 12:32 AM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Bad. Ass.
I ain't nobody, dork.
Old 04-15-2024, 10:32 PM
LetsFNgo's Avatar
LetsFNgo LetsFNgo is online now
Update for today both here and on the amc forum.
Spent some time under the rear of the car getting the gas tank into place and figuring out what rear shocks I need. Ended up figuring out that mid 70’s Matador shocks have the eyelet on the bottom that will work with the different shock mounting with the traction bars. Also spent time inside the car reinstalling the heater box. What a pain in the ass that was holy hell. I ended up having to pull the whole dash forward to slide the box into place. And when I was all done realized the wire that’s supposed to poke out of the heater core hole wasn’t there. So now I get to loosen everything up to try and fish that out. Lucky me.
Otherwise didn’t get too much done. The heater core was a real pain and I was outside playing with my 1 year old son. Little bugger filled the Dominators on the Tunnel Ram with bolts lol.
The Following 4 Users Say Thank You to LetsFNgo For This Useful Post:
big gear head (04-16-2024), Dave Rifkin (04-17-2024), markinnaples (05-01-2024), RPOLS3 (04-23-2024)
  #23
Old 04-23-2024, 12:01 AM
LetsFNgo's Avatar
Have a nice sized update today. I’ve been working on stuff but nothing picture worthy. I now have working brakes and my complete fuel system is plumbed from beginning to end.
Started this morning by cleaning out in front of the car and getting it pushed outside. Spent time today getting the interior put together. The carpet isn’t original but was put in the car in the late 70’s. So I decided to keep it. I carpet cleaned it yesterday and got it installed this morning along with the ugly green Javelin seats I picked up.
Next was cleaning the rest of the interior and installing the rear seat. Overall I’m happy with the inside of the car. My dad and I then spent some time cleaning the paint. Or at least starting to. My 1 year old had other plans for us so we gave up on the paint for today.
Overall got quite a bit done. Hopefully my driveshaft is done tomorrow and I can get the trans filled with oil after that and start getting the engine wired up to run.
AMC weirdo
The Following 7 Users Say Thank You to LetsFNgo For This Useful Post:
big gear head (04-23-2024), L78_Nova (04-23-2024), markinnaples (04-23-2024), olredalert (04-23-2024), PeteLeathersac (04-25-2024), scuncio (04-23-2024), Tenney (04-23-2024)
  #24
Old 04-23-2024, 12:47 AM
bugsy bugsy is offline
nice car. i sold one last year. 1971 sc 360. 1 of 19 built, 2 barrel with a 3 speed trans. 1 owner low miles, window sticker, protect o plate, low miles in very good condition. guy that bought it has it running.
Old 04-27-2024, 10:49 AM
LetsFNgo's Avatar
Spent some time yesterday going through wiring on the car and was able to get 12 volts to the coil. Then figured what the hell and threw 5 gallons of 100LL in the tank and filled the bowls and the car fired right up. Broke the cam in and got it to idle around 800.
I had initial timing set around 8-10 degrees before it slipped time backing it into the garage and backfired hard enough to pop the dipstick a foot out of the tube. I’ll have to retime it over the weekend and reset the idle. Otherwise I’m happy.
Took it for a quick ride around the block to make sure it shifts. I need to adjust the clutch a touch but again, overall it works just fine. I’m not sure if I can post a video here. If I can’t I’ll put up a couple of screenshots from the vids.
AMC weirdo
The Following 12 Users Say Thank You to LetsFNgo For This Useful Post:
big gear head (04-27-2024), BJCHEV396 (04-27-2024), cheveslakr (04-28-2024), Dave Rifkin (04-27-2024), dustinm (05-02-2024), L_e_e (05-02-2024), markinnaples (05-01-2024), PeteLeathersac (04-27-2024), RPOLS3 (05-08-2024), ScottG (04-30-2024), Stihl (06-11-2024), Tenney (04-27-2024)
  #26
Old 05-02-2024, 12:59 AM
LetsFNgo's Avatar
Update for today.
Got the engine back in time set about 12 Btdc. Turned the car around in the garage and my dad and I got to work. He’s been messing around with the paint trying to get it to come back to life a little. It’s an early 80’s Maaco respray so it’s not great. But the paint is coming out much better than I expected. Otherwise I started working on getting the lights to work and putting the rear lights and bumper back on. Going to work on more assembly stuff tomorrow.
Also need to figure out an exhaust. Hoping I can order down pipes off the manifolds and make my own exhaust through the Sonic Turbos.
AMC weirdo
The Following 14 Users Say Thank You to LetsFNgo For This Useful Post:
big gear head (05-02-2024), Dave Rifkin (05-02-2024), dustinm (05-02-2024), gtomike1967 (05-02-2024), Jeffp920 (05-02-2024), L78_Nova (05-02-2024), L_e_e (05-02-2024), markinnaples (05-02-2024), olredalert (05-02-2024), PeteLeathersac (05-02-2024), RPOLS3 (05-08-2024), Ryan1969Chevelle (05-02-2024), scuncio (05-02-2024), Tenney (05-02-2024)
  #27
Old 05-02-2024, 03:15 PM
Ryan1969Chevelle's Avatar
Originally Posted by LetsFNgo View Post
Update for today.
Where is Daddy’s sippy cup?
Great stuff!!!
Ryan W31
Old 05-04-2024, 04:54 AM
BJCHEV396's Avatar
Great story and project! Keep up the good work,I'll be following.
Old 05-04-2024, 04:41 PM
LetsFNgo's Avatar
Small update today. Have a party to go to this afternoon but had a little time to work on the car this morning. Replaced the front shocks and mounted the front bumper and grill so it starts looking like a car again. Then got under the car in the back and installed the left rear shock. I had to weld a tab onto the traction bar to do it, but it didn’t take long and came out nice.
Next step is the exhaust and wiper motor, then doing a lot of finish up work.
AMC weirdo
The Following 10 Users Say Thank You to LetsFNgo For This Useful Post:
1967Z28 (05-05-2024), 69M22Z (05-04-2024), big gear head (05-05-2024), Dave Rifkin (05-05-2024), markinnaples (05-08-2024), olredalert (05-05-2024), PeteLeathersac (05-04-2024), RPOLS3 (05-08-2024), scuncio (05-04-2024), Tenney (05-04-2024)
  #30
Old 05-16-2024, 07:57 PM
Daverde Daverde is offline
I absolutely love these cars!!
