Old 07-05-2024, 06:04 PM
BJCHEV396's Avatar
BJCHEV396 BJCHEV396 is online now
Default Change gear oil in a 12 bolt
Hi guys,I've never changed the oil in the 12 bolt of my Camino.Would 2 quarts of 80w90 and a 4 oz.bottle of posi additive be enough?Thanks,Bill.
Old 07-05-2024, 06:44 PM
bcmiller bcmiller is offline
2 quarts is usually enough.
The Following User Says Thank You to bcmiller For This Useful Post:
BJCHEV396 (07-06-2024)
Old 07-06-2024, 02:57 PM
Yes, unless you spill some.
bcmiller (07-06-2024)
Old 07-08-2024, 06:03 AM
Big Gear Head............Could you list what options we have for POSI ADDITIVE ????
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 07-08-2024, 11:53 AM
The GM additive still works most of the time. The Ford additive seems to work better, if you don't mind putting Ford oil in your Chevy. Amsoil makes a good additive. I don't like the stuff that comes in a tube at the auto parts stores.
Old 07-08-2024, 01:06 PM
SS427's Avatar
SS427 SS427 is offline
Don't spill it! You will have that unique smell in your shop/garage for weeks and it permeates everything!
I use only GM posi additive as I have had issues with anything else as far as clutch chatter.
Rick Nelson
Old 07-08-2024, 01:28 PM
Draining the old, used oil, is the strongest and worst, smell and there is no way to avoid getting that smell in a building, unless it is drained outside. The new oil, almost, smells good, compared to the old "stuff"...
396 SS/RS (07-09-2024)
Old 07-08-2024, 09:23 PM
I use the GM positraction axle gear lube in the old metal quart cans. I also use the limited slip differential fluid that comes in those small plastic containers. The old sperm whale fluid that is tuff to find these days.
I personally think it is better for the old original gears and posi plates.
Old 07-08-2024, 10:05 PM
BARRY BARRY is offline
HI YES old school metal cans of oil the best
Barry Allan
Old 07-09-2024, 02:10 AM
Rsconv68 Rsconv68 is offline
IIRC, all 12 bolt rear axles were not automatically a posi traction.
