Old 07-16-2024, 02:56 PM
daveg's Avatar
daveg daveg is offline
Default Parts taken off 69 L78 to get it running
Car sat for many years and these parts were replaced to get it running for sale.
I am going to put them back on.
Looks to be the factory installed stuff to me.
What say you?
Is the cap a no R type because the distributor is fairly early???
https://www.chevelles.com/threads/da...-blue.1168835/
The Following 4 Users Say Thank You to daveg For This Useful Post:
dykstra (11-15-2024), L78M22Rag (12-29-2024), olredalert (09-26-2024), ruralrte66 (07-17-2024)
Attachments - The Supercar Registry valve cap spare tire.jpg trunkstickers.jpg steering box tag.jpg smogl52.jpg
Old 07-16-2024, 03:20 PM
1967 4K's Avatar
1967 4K 1967 4K is offline
Got a pic of the inside of the cap?
Richard
1967 Camaro SS 396/375 4K
The Following User Says Thank You to 1967 4K For This Useful Post:
daveg (01-31-2025)
Old 07-16-2024, 03:22 PM
daveg's Avatar
No but I can get one later today. What am I looking for?
Old 07-16-2024, 03:46 PM
1967 4K's Avatar
Just see what kind shape the rotor button contact points look like. The rotor button looks good IMO.
That dab of purple paint on the dist. has got me thinking 🤔. It might be a factory inspector mark. Others may know something about it.
Been a long time since I’ve fooled with caps. There’s non R, R caps, non patent pending, patent pending and just AC DELCO. Different years for different lettering. Probably go to the CRG site and get that info.
The 499 distributor is definitely very cool 😎!!!
What’s the build date of the car?
Richard
daveg (01-31-2025)
Old 07-16-2024, 03:52 PM
Kurt S Kurt S is offline
The purple stripe was color ID for the engine plant. Many different colors used.
Kurt S - CRG
The Following 3 Users Say Thank You to Kurt S For This Useful Post:
daveg (01-31-2025), dykstra (07-17-2024), X66 714 (07-16-2024)
Old 07-16-2024, 04:59 PM
1967 4K's Avatar
Thanks Kurt, I knew that had some significance. If it was mine I’d try to keep that mark when cleaning up the piece.
Richard
daveg (01-31-2025)
Old 07-16-2024, 08:01 PM
daveg's Avatar
Distributor is as clean as it is going to get.
Car had 24,124 miles on it when we picked it up. It now has 24,779 miles.
Not going to restore or repaint it.
Pic of inside of cap.
The points and condenser were Echlin so did not bother with them.
Plug wires were changed also.
Thanks to all.
Dave
The Following 2 Users Say Thank You to daveg For This Useful Post:
Old 07-16-2024, 08:40 PM
1967 4K's Avatar
Cap looks good to me. Keep us posted as the clean up continues. I’m a big block fan especially the L78’s. 👍
The reason I ask about your cars build date was to see how close the distributor date was to the car. It’s an early 499.
Thanks,
Richard
daveg (01-31-2025)
Old 07-16-2024, 11:10 PM
Was it mentioned elsewhere and I missed it?
Do we know the Cowl tag assembly date of this car?
How about the Tonawanda engine assembly date behind the Alt.or maybe down by the oil filter instead?
daveg (01-31-2025)
Old 07-17-2024, 12:11 AM
I don't believe the rotor is original.
E stood for "emission" unless I am uninformed. Slightly larger gap between rotor and cap terminal.
http://www.camaros.org/forum/index.php?topic=15310.0
daveg (01-31-2025)
