Old 07-18-2024, 07:29 PM
427.060 427.060 is offline
Default 1968 Camaro Question
Is there anything in the VIN or on the trim tag that will tell if a 68 Camaro is a SS or if it came with a small block or a big block?
Thank you
1968 Beaumont SD396
Old 07-18-2024, 08:03 PM
X66 714's Avatar
X66 714 X66 714 is online now
Just the 3rd digit of the VIN tells you V8 or 6 cyl. Odd is a 6 cyl. Even is an 8 cyl. Nothing on the trim tag...Joe
Old 07-18-2024, 08:25 PM
Thank you. I am checking into this for a friend, It is a customer's car. All I know so far is that the first five numbers are 12437 which is a 8 cylinder coupe.
1968 Beaumont SD396
The Following User Says Thank You to 427.060 For This Useful Post:
X66 714 (07-18-2024)
