Old 07-20-2024, 07:07 PM
hvychev hvychev is offline
Default 1963 Catalina Tire Size Recco
Can someone help me out…..I have a 63 Catalina with 8 lug 14” wheels. I want to add the closest to CORRECT BIAS PLY white walls to the car. Can someone link me to the correct style and size on Coker Tire?
My car originally had a code PO1
Frank Magallon
Attachments - The Supercar Registry SD Cat.JPG cat @ Hershey.jpg 63 GP at Tech Center.JPG
Old 07-21-2024, 01:14 PM
I believe the original tire was an 8.00 x 14. They didn't list aspect ratio then, but most were 78.
Have no idea which white wall you need. Bet someone at PY could help out.
Here is a link for the only one that popped up on that size. Don't know if this wide white is correct though:
https://www.cokertire.com/tires/800-...wall-tire.html
Rusty Small can probably help you get what you need. Screen name is SmallHurst.
Old 07-21-2024, 01:15 PM
PY website: https://forums.maxperformanceinc.com/forums/
Old 07-21-2024, 01:58 PM
John Brown's Avatar
Tire Rack tire size conversion chart.
https://www.tirerack.com/upgrade-gar...old-tire-sizes
John Brown
Old 07-21-2024, 10:01 PM
Thank you all!
Frank Magallon
Old 07-22-2024, 12:46 PM
Keith Seymore's Avatar
Should be 1" white wall.
"PO1" sounds like the RPO for the full wheel cover (at least that is what it represents these days); not a tire RPO.
K
'63 LeMans Convertible
'63 Grand Prix
markinnaples (07-23-2024)
Old 07-22-2024, 01:56 PM
"PO1" sounds like the RPO for the full wheel cover (at least that is what it represents these days).
K
----Yes! My 64 GP in members area has 1 inch whitewalls....Bill S
Old 09-20-2024, 03:49 PM
Tommy Nolen Tommy Nolen is offline
Default 63 tire size
Don't know if this helps, this is my 63 Catalina, 8:50x14 B.F. Goodrich with 1" whitewall. Tires came from Coker. Standard size for 63 is 8:00x143 with 8:50 optional. Picture didnt load, will try again
Tommy's Toy
1959 Pontiac Catalina 420a / 3 speed manual
1960 Pontiac Ventura 4 speed
1961 Pontiac Catalina 4 speed
1961 Pontiac Ventura 425a / 4 speed
1962 Chevrolet Corvette
1963 Pontiac Catalina 421/4 speed
1964 Pontiac Catalina 2+2 tri power/4 speed
Old 09-20-2024, 03:59 PM
My 63 with 8:50x14 with 1" whitewalls
Tommy's Toy
The Following 4 Users Say Thank You to Tommy Nolen For This Useful Post:
dykstra (09-21-2024), John Brown (09-20-2024), olredalert (09-20-2024), Tenney (09-21-2024)
