Old 08-12-2024, 10:47 PM
1969camarors427's Avatar
1969camarors427 1969camarors427 is offline
Default 1968 Camaro Chevelle 396-350 hp Rochester Carb, 702818 EH, Dated August 20 1967.
1968 Chevelle Camaro 396-350hp with Automatic Transmission, Rochester Carb #702818 EH, Dated August 20 1967 (2367).
The date code on this carb is stamped on the baseplate as in the picture which is correct for this carb.
Carb is complete with 2 of the original long bolts, a mounting gasket and a used air cleaner gasket in good shape.
At one time in the past someone added a plug for most likely had a fuel gauge fitting and installed the plug, directly across from the fuel inlet.
Carb is located in Alberta Canada but shipping is no problem.
$200.00 USD, Accept Paypal F&F.
If you need any other pictures send a message.
Last edited by 1969camarors427; 08-15-2024 at 05:22 PM. Reason: information and price
Attachments - The Supercar Registry 20240803_174955_resized.jpg 20240803_174943_resized.jpg 20240803_174937_resized.jpg 20240803_174821_resized.jpg
Tags
camaro chevelle l34 396
