Old 09-19-2024, 08:07 PM
ALLZS ALLZS is offline
Default Dash carrier resto
is there still anyone restoring the original 69 camaro dash carriers
Attachments - The Supercar Registry Stud fixed.jpg Stud crack.jpg Repaired Radio Knob.jpg Radio cutout.jpg
Old 09-19-2024, 09:26 PM
William William is offline
Just my 2˘ from 49 years of '69 Camaros. I wouldn't bother. Originals were brittle 20 years ago; wiper switch pegs and the lower trim cover tabs usually broken off.
There have been two repros available for some time, both well-done.
The Following 4 Users Say Thank You to William For This Useful Post:
Big Block Bill (09-20-2024), dykstra (09-23-2024), olredalert (09-19-2024), scuncio (09-19-2024)
Old 09-19-2024, 11:05 PM
thehornworks thehornworks is offline
Check with Mike at Instrument Specialties
Old 09-20-2024, 12:27 AM
on the repro ones what is the best one out there
Old 09-20-2024, 01:00 PM
rlw68's Avatar
rlw68 rlw68 is offline
I used Polyvance Plastifix to rebuild the bottom of the radio opening and knobs where it had been cut out. It also worked great on a cracked wiper switch stud, and a missing tab.
https://www.polyvance.com/PlastiFix-Kits-1/2503/
The steps for reconstructing a tab are shown in this vid
Their website has videos for other types of repairs. Pictures of mine below.
Using the molding putty to rebuild this wallowed out radio knob hole
Name:  Repaired Radio Knob.jpg
Studs are easy. Platifix can be applied in layers to reinforce these also.
Name:  Stud crack.jpg
Name:  Stud fixed.jpg
The area where the bottom of the radio opening was cut out was also repaired using the molding putty.
Name:  Radio cutout.jpg
Radio opening rebuilt, knob holes filled, and new tab added
Name:  Dash front.jpg
Rob
The Following 8 Users Say Thank You to rlw68 For This Useful Post:
62sedan (09-20-2024), 69M22Z (09-20-2024), dykstra (09-23-2024), mhm1966 (09-20-2024), RPOLS3 (09-20-2024), scuncio (09-21-2024), SS427 (09-20-2024), TerryD (09-20-2024)
Old 09-20-2024, 01:57 PM
Polyvance is really nice to work with.
Old 09-21-2024, 02:45 AM
Rsconv68 Rsconv68 is offline
I’ve had good luck with JB Plastic Bond, and it’s black.
