Old 10-09-2024, 05:56 PM
GM Powertrain's Avatar
GM Powertrain GM Powertrain is offline
Originally Posted by 60sStuff View Post
Mr. Mattison actually suggested that, shocking!
Hey Jim, why stop there, drop in an LS motor too 🙄
He was adamant about it actually. Maybe the beverage he was drinking at dinner that evening?
A 4 speed or an LS is going will never happen during my ownership.
1971 Nova SS BBC and 3 Pedals
1965 442 Post Coupe
1987 Buick Turbo T ex GM High Tech Performance Magazine project car
10.45 @ 128.71
'87 Buick Regal Turbo T Stock 48,000 miles
2015 Challenger SRT Hellcat 5400 miles
2014 F150 Supercab Ecoboost - Livernois Motorsports tuned
Formers: '67,69 and '73 SS Chevelles
'65 Biscayne 427
'66 Caprice 396
'72 LeMans Y code 455 VIN 007
6 GN and Turbo T's, 2 Wildcats, GS, 2 Skylarks ...and a partridge in a pear tree.
The Following User Says Thank You to GM Powertrain For This Useful Post:
60sStuff (10-09-2024)
  #22
Old 10-09-2024, 10:15 PM
WILMASBOYL78's Avatar
Post 442 Tranny Swap...
Originally Posted by GM Powertrain View Post
2.74 first gear for more bottom end punch and OD for cruising with ease as well as less wear and tear. As a bonus it literally bolts right in with nothing more than moving the crossmember back.
A win on many levels.
So...2004R is the same length as a PG..?? Would a good TH350 be an option as well...it has a 2.52 first gear?? Of course, then there is no O/D.
Will you be able to use the stock driveshaft??
It is a great looking car
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
The Following User Says Thank You to WILMASBOYL78 For This Useful Post:
GM Powertrain (10-10-2024)
  #23
Old 10-10-2024, 08:33 PM
Same length. Yes a Turbo 350 will work fine too but if your going to swap, why not have overdrive? The most important thing with the 200 (and 700) is proper TV cable set up. If not done correctly will smoke the trans in no time.
1965 442 Post Coupe
10.45 @ 128.71
'65 Biscayne 427
'66 Caprice 396
olredalert (10-10-2024)
  #24
Old 10-10-2024, 08:57 PM
60sStuff's Avatar
60sStuff 60sStuff is offline
So if someone wanted to modify this cool old ‘65 muscle car from it’s stock 2 speed Jetaway to a whatever 3 speed auto, or overdrive unit what happens to the factory steering column and shift indicator window ??
How far does one butcher a classic?
Sorry for my vent, but I have seen this happen way to often on these types of cars.
The Following 2 Users Say Thank You to 60sStuff For This Useful Post:
67since67 (10-10-2024), olredalert (10-10-2024)
  #25
Old 10-10-2024, 09:34 PM
People who have the done the swap generally use the Lokar linkage kit. as far as the shift indicator lens, I would leave it alone as well as the column as I wouldn't be shifting it. I'd want it to be a swap that wouldn't permanently alter anything whatsoever.
Nothing is decided yet. The Jetaway might stay. We'll see...
1965 442 Post Coupe
10.45 @ 128.71
'65 Biscayne 427
'66 Caprice 396
Old 10-10-2024, 10:21 PM
Post
I have used products from Shiftworks....they make quality stuff.
https://shiftworks.com/collections/c...s/column-shift
looks like the universal unit is for you...they even have indicator plates you can swap in.
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
GM Powertrain (10-11-2024)
  #27
Old 10-11-2024, 07:17 PM
tom406 tom406 is offline
I have a strong purist streak in me, but transmissions, particularly 2sp automatics, are such an inhibitor of performance and driving enjoyment, that I’m in favor of substitutions that don’t involve much in the way of tunnel or frame mods. Swapping a 2004r for a PG/Jetaway/Super Turbine 300 is such a transformative modification that nobody can really see if you execute it properly. Also, 2004R gives vintage BOP guys a bolt on transmission options without adapters or anything. It is literally adding a new low and a new high gear to the mix. Functionally this will improve performance more than most bolt ons and make highway driving less stressful on the car (and you). I feel the same way about upgrading steering boxes for faster ratio and better feel. Getting the linkage right and making the gear indicator appear factory is part of the challenge, but also part of the fun in finessing a solution that looks period correct and proper. My friend put a Borgeson power steering box in his 50k original mile ‘67 Fairlane GT because he got tired of fighting Ford external units and loved how the Borgesons drove. He painted everything to match, used OEM style hoses, used a correct Ford pump and even Ford guys don’t notice it unless you point it out.
The Following 6 Users Say Thank You to tom406 For This Useful Post:
69M22Z (10-11-2024), Crush (10-11-2024), GM Powertrain (10-13-2024), olredalert (10-11-2024), PeteLeathersac (10-12-2024), scuncio (10-13-2024)
  #28
Old 10-13-2024, 05:59 PM
Agree with everything you said. I'm sure the car will feel like it gained a bunch of horsepower by just doing this simple swap. It's very tempting.
1965 442 Post Coupe
10.45 @ 128.71
'65 Biscayne 427
'66 Caprice 396
Old 10-18-2024, 04:09 AM
BJCHEV396's Avatar
Congrats on the 4 4 2! Great color combo!
GM Powertrain (10-20-2024)
  #30
Old 10-19-2024, 01:09 PM
Congrats! Very clean and great looking car.
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
The Following User Says Thank You to sixt9rsx33 For This Useful Post:
