Old 10-12-2024, 01:13 AM
BLACKLS5 BLACKLS5 is offline
Default GM aluminum 842 heads open chamber?
Has anyone seen a set of 842 big block aluminum heads that were open chamber design? I have to believe these have been modified? Alan Colvin's book says the 1968 and early 69's has a screw in plug on both ends and late '69 had a plug on only one end. These don't have a screw in plug on either end. The date looks like 7 15 69.
The Following User Says Thank You to BLACKLS5 For This Useful Post:
Carleen (10-12-2024)
Attachments - The Supercar Registry 20241011_201028_resized.jpg 20241011_201017_resized.jpg 20241011_200846_resized.jpg
Old 10-12-2024, 02:52 AM
They all came closed chamber from GM. I have had many sets that we opened up to the open chamber design.
Those also had the extra(ZL1) head bolt boss added to the underside. The later service heads had no plugs on either end.
Jason
Jimlt4383 (10-15-2024)
Old 10-12-2024, 11:30 AM
Thanks Jason. That was what I assumed but wasn't 100% sure. Are the stories true about the seats coming loose on some of these early factory aluminum heads. I've had a few sets pass through my hands but didn't have the nuts to roll the dice and use a set for fear of ruining an engine.
Old 10-12-2024, 02:31 PM
I have had many sets that have been grenaded due to loosing a seat. Most of those were pushed to their performance limits so it’s hard to say the cause of the seat loss. I have also had many sets with no damage. When playing with the most high performance parts available at the time, it is expected to see some modifications and breakage.
Jason
Old 10-12-2024, 03:25 PM
----I was looking for a new 69 435 at a Columbus dealer when the sales guy said that they had a black convert L89 new, but in the service department. I asked why and he said they had one head off. When pressed he took me to the service head who told me it had dropped a seat. I decided to pass on L89's at that moment!....Bill S
The Following 3 Users Say Thank You to olredalert For This Useful Post:
dykstra (10-15-2024), L_e_e (10-13-2024)
Old 10-13-2024, 12:23 PM
Lol... Good story Bill.
Old 10-15-2024, 12:53 PM
Zman1969 Zman1969 is offline
Jason
My Machinist buddy made it sound like was every day occurrence on these heads and warned me not to get it hot
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 10-15-2024, 03:00 PM
I hope the problem was fixed with the 077 heads. I take mine to 7200-7300 pretty regular, with plans to go 7500 next year.
Old 10-17-2024, 02:50 AM
markjohnson's Avatar
markjohnson markjohnson is online now
The problem is that the expansion rate of aluminum is greater than the expansion rate of the steel valve seat insert. The aluminum head expands and the valve seat just falls right out if the machining tolerance isn’t dead on. The high end solution is copper beryllium valve seats that actually expand more than the aluminum so they really lock themselves into place.
The Following 6 Users Say Thank You to markjohnson For This Useful Post:
1967 4K (10-17-2024), BLACKLS5 (10-17-2024), Igosplut (10-17-2024), L78_Nova (10-17-2024), napa68 (10-20-2024), olredalert (10-17-2024)
Old 10-17-2024, 04:06 PM
Igosplut's Avatar
Igosplut Igosplut is offline
Funny you say this, as I had a valve seat fall out of an older Harley a while back,. and the machine shop used a copper/style seat to replace it, stating the very same reason.
WOT
