Old 09-28-2024, 12:22 AM
GotGrunt's Avatar
GotGrunt GotGrunt is offline
Default Hurst Super Shifter
Price:$450
Hard to find Hurst Super Shifter 2 with push down reverse, part number 4918777. It’s been completely gone through; new hardware was added as well as a Hurst pit pack with steel bushings. It comes with the mounting bracket, sleeved straight rods, levers, chrome stick, and shift knob. The shifter itself is universal and will work on most 4-speeds. The mounting bracket, rods, and levers will work with Muncie M20, M21, M22, or Borg Warner T10, Super T10, among others. $475
The Following User Says Thank You to GotGrunt For This Useful Post:
Damien (10-05-2024)
Attachments - The Supercar Registry IMG_4196.jpg IMG_4195.jpg IMG_4194.jpg IMG_4193.jpg
Old 09-28-2024, 11:08 PM
Very nice. Had one of those in my 69 Camaro that I drag raced 50 yrs ago....absolutely bulletproof. Couldn't miss a gear if you tried.
Bill Pritchard
The Following 2 Users Say Thank You to Bill Pritchard For This Useful Post:
GotGrunt (09-29-2024), lbnaz (09-28-2024)
Old 09-28-2024, 11:21 PM
luzl78 luzl78 is offline
Will it work on a 67 camaro with console?
Old 09-29-2024, 01:25 AM
GotGrunt's Avatar
The mounting bracket for the super shifter moves the entire shifter body up and over to be able to use straight rods. That may interfere with the console, but I can’t say for sure.
Old 09-29-2024, 01:19 PM
I seriously doubt it. I had to cut a sizable chunk out of the floor on my 69 Camaro in order to mount the shifter. As GotGrunt says, the shifter body is moved up and over toward the driver as compared to a stock shifter.
Bill Pritchard
Old 10-12-2024, 07:18 PM
GotGrunt's Avatar
Price drop!
Old 10-13-2024, 01:43 PM
outlawperformance outlawperformance is offline
PM sent.
Old 10-13-2024, 03:29 PM
Pretty sure I could. But then my brother always told me I could tear up a steel ball using a powder puff and a pair of tweezers.
But... if I were building a hot rod with a four speed, THIS is definitely the shifter I would want.
GotGrunt (10-13-2024)
Old 10-13-2024, 03:30 PM
GotGrunt's Avatar
Originally Posted by outlawperformance View Post
PM sent.
Replied!
Old 10-13-2024, 03:47 PM
Hope it is headed to a good home.
