![]() Price:$450
Hard to find Hurst Super Shifter 2 with push down reverse, part number 4918777. It’s been completely gone through; new hardware was added as well as a Hurst pit pack with steel bushings. It comes with the mounting bracket, sleeved straight rods, levers, chrome stick, and shift knob. The shifter itself is universal and will work on most 4-speeds. The mounting bracket, rods, and levers will work with Muncie M20, M21, M22, or Borg Warner T10, Super T10, among others. $475
The Following User Says Thank You to GotGrunt For This Useful Post: | ||
Damien (10-05-2024) |
Very nice. Had one of those in my 69 Camaro that I drag raced 50 yrs ago....absolutely bulletproof. Couldn't miss a gear if you tried.
Bill Pritchard 73 Camaro RS Z28, L82, M20, C60 |
Will it work on a 67 camaro with console?
The mounting bracket for the super shifter moves the entire shifter body up and over to be able to use straight rods. That may interfere with the console, but I can’t say for sure.
I seriously doubt it. I had to cut a sizable chunk out of the floor on my 69 Camaro in order to mount the shifter. As GotGrunt says, the shifter body is moved up and over toward the driver as compared to a stock shifter.
Price drop!
PM sent.
![]() Quote:
But... if I were building a hot rod with a four speed, THIS is definitely the shifter I would want.
The Following User Says Thank You to Lynn For This Useful Post: | ||
GotGrunt (10-13-2024) |
Hope it is headed to a good home.
