Old 10-27-2024, 03:35 PM
Well, after reading your picky butt liked these tires, I went looking for them to see what a set would cost....make yours last, they seem to be discontinued.... This happens all too often with me...find something I might like and they have become unobtainium.
I can't stand the Coopers I bought several years ago off tire rack. The pic was a true 5 rib, P series but the LT series came with a block tread that, even though I am half deaf, drive me nuts from the road noise and it's only getting worse as they wear...
Old 10-28-2024, 12:35 AM
i believe they recently renamed them Bridgestone R265 5-Rib Load Range E
https://www.tirerack.com/tires/tires...omCompare1=yes
Old 10-28-2024, 12:56 AM
Yes, but it only comes in 1 size and it's not the size I need.
Old 10-28-2024, 01:21 AM
What size do you need Mitch?
The R265 5-Rib Load Range E posted is definitely the same tread pattern.
Old 10-28-2024, 02:29 AM
The size associated with the R265 is listed as 245/75/16. I need 265/70/17. Could be a misprint, but I chased this around the web for 1/2 hour this morning trying to find a 265.
Old 10-28-2024, 03:36 AM
Do you need load range E?
Old 10-28-2024, 10:57 AM
It's what I prefer as a safety margin for pulling the trailers. Way over rated for a 1500 Silverado, but when I travel with the car trailer, I carry a LOT of "stuff" with for emergencies and such.
Old 10-28-2024, 11:30 AM
luzl78 luzl78 is online now
i put falkens on me ram 2500 with the cummins and theyve lasted 45,000 miles. not many tires last long with that heavy diesel in the front. they run super quiet.
The Following User Says Thank You to luzl78 For This Useful Post:
Too Many Projects (10-28-2024)
  #39
Old 10-28-2024, 05:57 PM
Donnie's Avatar
Donnie Donnie is offline
thats why I stick with the MICHELIN LTX A/T 2 ... 60,000 mile warranty and they are quiet.
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 11-29-2024, 04:26 PM
Anyone have a truck with the Allison trans from this period. After changing the fluid and both filters, I have a small leak. Didn't even have a drip before the change. Not leaking from either the pan or the external filter. The leak is EITHER from the shift seal OR the gasket/seal located under the electrical plug at the back of the trans.
Guessing neither of those is that difficult to fix.
